请教下,参数调用数据集问题
参数调用sql语句,但是语句拼接不成功
${if(len(oop)!=0  && oop != "00000001" &&  len(yg)==0  ,
("select '一区' ,sum(lw_cnt)
from dm_dwlwzs_info
where 1=1 and gsdwh='"+ oop +"'"
+ if(len(tbsj_ks) == 0,"","and tjny >= '" +tbsj_ks + "'")
+ if(len(tbsj_js) == 0,"","and tjny <= '" +tbsj_js + "'")
union
select  '二区', sum(lw_cnt)
from dm_dwlwzs_info
+ if(len(tbsj_js) == 0,"","and tjny <= '" +tbsj_js + "'")' )
FineReport 随心灵 发布于 2023-6-9 14:19 (编辑于 2023-6-9 14:20)
发布于2023-6-9 14:21(编辑于 2023-6-9 14:25)
改成这样
"select '二区',sum(lw_cnt)
from dm_dwlwzs_info
+ if(len(tbsj_js) == 0,"","and tjny <= '" +tbsj_js + "'")+
" union
from dm_dwlwzs_info
  • 随心灵 随心灵(提问者) 大佬,能顺带说下我的问题不,让我进步点
    2023-06-09 14:23
  • snrtuemc snrtuemc 回复 随心灵(提问者) 框出来的有问题
    2023-06-09 14:25
  • 随心灵 随心灵(提问者) 好的,谢谢,我先把我的弄好,完了好好琢磨下
    2023-06-09 14:27
  • snrtuemc snrtuemc 回复 随心灵(提问者) 其实你两个sql语句union,需要字段相等,我第一个sql给你加了个固定 二区,,你根据实际修改下,拷贝我的语句直接测试下先
    2023-06-09 14:28
  • 239浏览人数
  • 最后回答于:2023-6-9 14:25
