参数分组无效
大佬们,好像是我分组的位置不正确,但是我不知道怎么改,帮忙看下${if(len(oop)!=0  && oop != "00000001" &&  len(yg)==0  ,
"select xx.dwmc, sum(dm.xmdzzjf) zs
from dm_jyshxxm_info  dm
left join
xx_yxsdwjbsj xx on   dm.dwh=xx.dwh
where 1=1 and  (dm.dwh = '" +oop+ "' or dm.lsdwh = '" +oop+ "') "
+ if(len(tbsj_ks) == 0,"","and tjny >= '" +tbsj_ks + "'")
+ if(len(tbsj_js) == 0,"","and tjny <= '" +tbsj_js + "'") group by xx.dwmc,
FineReport 随心灵 发布于 2023-6-9 16:47
发布于2023-6-9 16:48
left join
+ if(len(tbsj_js) == 0,"","and tjny <= '" +tbsj_js + "'")+" group by xx.dwmc",
shirokoLv6资深互助
发布于2023-6-9 16:48(编辑于 2023-6-9 16:52)
image.png填入参数,点这个看看对应的实际sql,应该是语法有问题
image.png你这个group by 要放到字符串里,或者{}的外边
luojian0323Lv7资深互助
发布于2023-6-9 16:49
很明显 的语法错误,后面的group by 不在双引号内。
  • 261浏览人数
  • 最后回答于:2023-6-9 16:52
