大佬们,帮忙看下参数
${if(len(yg) == 0 &&  (oop=='00000001' || len(oop)==0)  ,
"select hx.dwmc,hxzs,zxzs,sum(hxzs+zxzs) from
           (select xx.dwmc, sum(dm.xmdzzjf) hxzs  from dm_hxxm_info  dm
                    left join     xx_yxsdwjbsj xx on   dm.dwh=xx.dwh
                   where 1=1   group by xx.dwmc )hx
left join
           (select xx.dwmc, sum(dm.xmdzzjf) zxzs   from dm_zxxm_info  dm
             left join
                      where 1=1 group by xx.dwmc ) zx on hx.dwmc=zx.dwmc
where 1=1"
+ if(len(tbsj_ks) == 0,"","and tjny >= '" +tbsj_ks + "'")
+ if(len(tbsj_js) == 0,"","and tjny <= '" +tbsj_js + "'") +"
group by hx.dwmc,hxzs,zxzs
order by hxzs desc",
 ${if(len(yg) != 0 &&  (oop=='00000001' || len(oop)==0)  ,
                   where 1=1  and fzrh='yg' group by xx.dwmc )hx
left join
             left join
                      where 1=1 and fzrh='yg' group by xx.dwmc ) zx on hx.dwmc=zx.dwmc
where 1=1"
${if(len(yg) == 0 &&  (oop!='00000001' || len(oop)!=0)  ,
           (select xx.dwmc, sum(dm.xmdzzjf) hxzs  from dm_jyshxxm_info  dm
                   where 1=1  and dm.lsdwh='"+oop+"' group by xx.dwmc )hx
left join
           (select xx.dwmc, sum(dm.xmdzzjf) zxzs   from dm_jyszxxm_info  dm
             left join
                      where 1=1 and dm.lsdwh='"+oop+"' group by xx.dwmc ) zx on hx.dwmc=zx.dwmc
where 1=1"
当我oop和yg不输入任何数据的时候,应该调用第一个,但是报错,提示我select附近语法错误,单独执行就都可以
FineReport 随心灵 发布于 2023-6-11 17:41 (编辑于 2023-6-11 17:54)
发布于2023-6-11 18:39(编辑于 2023-6-11 18:40)
语法是错的改成如下:
left join
             left join
where 1=1"
left join
             left join
where 1=1"
order by hxzs desc" ,
if(len(yg) == 0 &&  (oop!='00000001' || len(oop)!=0),
left join
             left join
where 1=1"
order by hxzs desc","")))}
  • 随心灵 随心灵(提问者) 好的,我试下,非常感谢哈
    2023-06-11 18:53
  • 随心灵 随心灵(提问者) 哈喽大佬,方便给我说下,我错的原因不,平时有点笨。。。
    2023-06-11 19:31
  • CD20160914 CD20160914 回复 随心灵(提问者) if多个条件的判断语句 是 if(a=1,\"要的结果\",if(a=2,\"结果2\",if(a=3,\"要的结果3\",\"\")))
    2023-06-11 20:13
  • CD20160914 CD20160914 回复 随心灵(提问者) 所以上面用了变量的也要用这个语法。这个函数的基本语法要学会了才知道它的标准写法
    2023-06-11 20:13
  • 随心灵 随心灵(提问者) 回复 CD20160914 这个斜杠有点误导人,可以截个图不
    2023-06-11 22:10
  • 255浏览人数
  • 最后回答于:2023-6-11 18:40
