错误代码:61300110spider计算引擎服务初始化异常
错误日志:
Caused by: com.finebi.spider.common.exception.standard.SparkInitialException: 错误代码:61300110spider计算引擎服务初始化异常
at com.finebi.spider.common.exception.handler.spark.SparkInitialExceptionHandler.handle(SparkInitialExceptionHandler.java:15)
at com.finebi.exception.handler.EngineExceptionHandlerManager.handle(EngineExceptionHandlerManager.java:22)
at com.finebi.base.concurrent.future.WrappedFuture.getHandler(WrappedFuture.java:89)
at com.finebi.base.concurrent.future.WrappedFuture.getUntilEnd(WrappedFuture.java:130)
at com.finebi.base.concurrent.future.FutureFactory.lambda$futureAndThen$6(FutureFactory.java:174)
at com.finebi.base.concurrent.future.FutureFactory.lambda$wrapSupplier$8(FutureFactory.java:203)
at com.finebi.base.concurrent.ExecutorServiceFactory$PrintExceptionExecutorService.lambda$wrap$1(ExecutorServiceFactory.java:226)
... 5 common frames omitted
Caused by: java.lang.NoClassDefFoundError: Could not initialize class com.finebi.spider.cluster.spark.ContextManager
at com.finebi.spider.etl.job.spark.source.SparkEtlNormalSourceBuilder.streamSource(SparkEtlNormalSourceBuilder.java:51)
at com.finebi.spider.impl.etl.ETLProcessBuilderHelperImpl.buildMemorySource(ETLProcessBuilderHelperImpl.java:162)
at com.finebi.spider.impl.etl.ETLProcessBuilderHelperImpl.buildSource(ETLProcessBuilderHelperImpl.java:142)
at com.finebi.spider.impl.etl.AbstractProcessBuilderHelper.etlProcessBuilder(AbstractProcessBuilderHelper.java:37)
at com.finebi.spider.impl.etl.procedure.ETLSaveAsyncProcedure.lambda$process$0(ETLSaveAsyncProcedure.java:34)
... 7 common frames omitted
2023/06/13 00:00:08 baseTable-load-pool-37-thread-9 ERROR [standard]  catch exception
FineBI yzm124544 发布于 2023-6-13 09:44
luojian0323Lv7资深互助
发布于2023-7-13 20:35
我今天遇到了这个问题,重启服务就自动恢复正常了。
  • 武恩赐 武恩赐 重启服务器吗
    2023-10-16 17:05
  • luojian0323 luojian0323 回复 武恩赐 重启服务指的是shuttdown掉BI进程,然后重启BI服务
    2023-10-16 17:08
  • 武恩赐 武恩赐 回复 luojian0323 我也是重启服务,还是不行,不知道原因,错误代码不太适合我这个场景,都看了没有什么问题
    2023-10-16 17:14
  • luojian0323 luojian0323 回复 武恩赐 实在解决不了的可联系一下帆软在线技术支持
    2023-10-17 08:18
  • 武恩赐 武恩赐 回复 luojian0323 好的 感谢
    2023-10-17 08:41
帆软用户sI3K2sS400Lv2见习互助
发布于2024-4-23 17:45
我也遇到类似问题了
  • 642浏览人数
  • 最后回答于:2024-4-23 17:45
