预览报错
大佬们,这个一般是什么原因,没排查出来
${if(len(oop)!=0  && oop != "00000001" && len(yg)==0 &&  len(zrcy) == 0,
"select '一区', sum(jcr_1_zone) jcr
from dm_dwlwfqhz_info
where 1=1 and  gsdwh='" + oop +"'"
+if(len(tbsj_ks) == 0,"","and tjny >= '" +tbsj_ks + "'")
+if(len(tbsj_js) == 0,"","and tjny <= '" +tbsj_js + "'")+
"union
select  '二区',sum(jcr_2_zone)  jcr
where 1=1 and gsdwh='"+ oop +"'"
+if(len(tbsj_ks) == 0,"","and tjny>='" +tbsj_ks +"'")
+if(len(tbsj_js) == 0,"","and tjny<='"  +tbsj_js  + "'")+
" union
select  '三区', sum(jcr_3_zone)  jcr
+if(len(tbsj_ks) == 0,"","and tjny >='" +tbsj_ks +"'")
+if(len(tbsj_js) == 0,"","and tbsj_js <='" +tbsj_js +"'")+
"union
sselect  '四区', sum(jcr_4_zone)  jcr
+if(len(tbsj_ks)==0,"","and tjny>='" +tbsj_ks +"'"
+if(len(tbsj_js)-==0,"","and tbsj_js<='" +tbsj_js +"'")
FineReport 随心灵 发布于 2023-6-20 15:11
shirokoLv6资深互助
发布于2023-6-20 15:19
你这上面复制的,左右括号数量都不一样多,少了一个右括号
  • 随心灵 随心灵(提问者) 那像这种的报错,一般是什么原因呢,是因为少了什么符号或者引号造成的吗
    2023-06-20 15:22
  • shiroko shiroko 回复 随心灵(提问者) 这种是语法错误,涉及很多,少个逗号等号括号引号,字母打错都有可能
    2023-06-20 15:25
发布于2023-6-20 15:20
+if(len(tbsj_js) == 0,"","and tjny <= '" +tbsj_js + "'")+"union
" union
"union
+if(len(tbsj_ks)==0,"","and tjny>='" +tbsj_ks +"'")
+if(len(tbsj_js)==0,"","and tbsj_js<='" +tbsj_js +"'")
发布于2023-6-20 15:21(编辑于 2023-6-20 15:23)
这个括号少了
ID1208Lv6高级互助
发布于2023-6-20 15:22(编辑于 2023-6-20 15:22)
感觉可能if的结构有点问题
可以先把语句单独拿出来,执行一下看有没有报错
  • 392浏览人数
  • 最后回答于:2023-6-20 15:23
