远程设计连接超时错误代码11300104
错误堆栈信息:
com.fr.workspace.engine.exception.RemoteDesignConnectionException: com.fr.third.org.apache.http.conn.HttpHostConnectException: Connect to 192.168.0.112:8080 [/192.168.0.112] failed: Connection timed out: connect
at com.fr.workspace.engine.convert.NetworkConnectionErrorConverter.convert(NetworkConnectionErrorConverter.java)
at com.fr.workspace.engine.convert.ExceptionConverter.convert(ExceptionConverter.java)
at com.fr.workspace.engine.channel.http.WorkspaceHttpConnector.compatibleGet(WorkspaceHttpConnector.java)
at com.fr.workspace.engine.channel.http.WorkspaceHttpConnector.get(WorkspaceHttpConnector.java)
at com.fr.workspace.engine.channel.http.FunctionalHttpRequest.validateVT(FunctionalHttpRequest.java)
at com.fr.workspace.engine.channel.WorkspaceChannelFactory.testConnection(WorkspaceChannelFactory.java)
at com.fr.workspace.engine.client.FineWorkspaceConnector.testConnection(FineWorkspaceConnector.java)
at com.fr.env.RemoteEnvPane$7.doInBackground(RemoteEnvPane.java:595)
at com.fr.env.RemoteEnvPane$7.doInBackground(RemoteEnvPane.java:591)
at javax.swing.SwingWorker$1.call(SwingWorker.java:295)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at javax.swing.SwingWorker.run(SwingWorker.java:334)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Caused by: com.fr.third.org.apache.http.conn.HttpHostConnectException: Connect to 192.168.0.112:8080 [/192.168.0.112] failed: Connection timed out: connect
at com.fr.third.org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:156)
at com.fr.third.org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:376)
at com.fr.third.org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:393)
at com.fr.third.org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:236)
at com.fr.third.org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:186)
at com.fr.third.org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:89)
at com.fr.third.org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:185)
at com.fr.third.org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:83)
at com.fr.third.org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:108)
at com.fr.workspace.engine.channel.http.WorkspaceHttpConnector.execute(WorkspaceHttpConnector.java)
... 14 more
Caused by: java.net.ConnectException: Connection timed out: connect
at java.net.DualStackPlainSocketImpl.connect0(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:79)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:589)
at com.fr.third.org.apache.http.conn.socket.PlainConnectionSocketFactory.connectSocket(PlainConnectionSocketFactory.java:75)
at com.fr.third.org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:142)
... 23 more
FineReport TimothySheng 发布于 2023-6-26 00:27 (编辑于 2023-6-26 00:29)
TimothyShengLv4见习互助
发布于2023-6-27 14:36
解决方法:
(1) 打开控制面板
(2) 进入,控制面板\所有控制面板项\Windows Defender 防火墙  (可输入到地址栏中,回车后直接到达)。
点击左侧菜单中的"高级设置"。
(3) 入站规则→新建规则,点击"入站规则"后点击"新建规则"。
(4) 在“要创建的规则类型”中,选择“端口”,下一步。
(5)选择"TCP",选择"特定本地端口(S)"后填入端口号8090 (不同的人的端口名不同,具体看自己是否设置过,默认是8080),下一步。
(6) 选择允许连接,下一步。最后,紧接着为这个规则命名,完成。
最后就可以看到(3)中的标记3的效果。
设置如上操作后,PC或服务器不用重启,只需要客户端刷新下就可以访问了。
版权声明:本文为CSDN博主「huayang183」的原创文章,遵循CC 4.0 BY-SA版权协议,转载请附上原文出处链接及本声明。
原文链接:https://blog.csdn.net/qq_18671415/article/details/119446687
发布于2023-6-26 07:45
  • 6825浏览人数
  • 最后回答于:2023-6-27 14:36
