JSON数据集相关问题
根据帮助文档写了一个控件参数传参,price为8.95时能查出来数据,那为空的时候怎么查全表呢?我上边的写法是错误的,另外这是什么程序呢?
var books = $.store.book; var rowCount = books.length; var table = []; var column = []; books.forEach(function(value, index) {     var row = []; if('${price}'!=0){ if (value.price =='${price}') { for (var key in value) { row.push(value[key]); column.push(key); } table.push(row); } }     }); return merge(table, unique(column));
FineReport 愤怒的老头 发布于 2023-6-27 11:10 (编辑于 2023-6-27 13:21)
愤怒的老头Lv3见习互助
发布于2023-6-27 15:05
var table = [];
var column = [];
    var row = [];
if ('${category}'==0 && '${author}'==0 && '${title}'==0  && '${price}'==0  && '${isbn}'==0  ){
column.push(key);
table.push(row);
else {
if (value.category =='${category}' || value.author =='${author}' || value.title =='${title}' || value.price =='${price}' || value.isbn =='${isbn}' ) {
column.push(key);
table.push(row);
shirokoLv6资深互助
发布于2023-6-27 11:19
console.log("行数为:" + rowCount);
var table = [];
var column = [];
    var row = [];
        if('${price}'==''||('${price}'!=0 && value.price=='${price}')){
            column.push(key);
    console.log("该行共有" + row.length + "列");
    table.push(row);
  • 愤怒的老头 愤怒的老头(提问者) 大腿,我还有个问题,如果再加一个参数控件该怎么写呢,比如说NAME
    2023-06-27 11:22
  • shiroko shiroko 回复 愤怒的老头(提问者) 再加,加了功能是啥呢?
    2023-06-27 14:05
  • 愤怒的老头 愤怒的老头(提问者) 回复 shiroko 类似于sql里的 ${if(len(price) == \"0\", \"\", \"AND price = \'\"+price+\"\'\")} ${if(len(name) == \"0\", \"\", \"AND name = \'\"+name+\"\'\")}
    2023-06-27 14:34
  • shiroko shiroko 回复 愤怒的老头(提问者) 你这样子采纳的?
    2023-06-27 15:38
  • 257浏览人数
  • 最后回答于:2023-6-27 15:05
