sql问题
怎么使用switch嵌套if参数,如${switch(bt,"0","select xxx from t
where 1=1
${if(len(p)==0 …)}
,"1","select xxx from bb
where 1=1
${if(len(p)==0…)}")}等类似功能要求两个参数都要生效
FineReport yzmRDmG31629904 发布于 2023-6-27 16:34
发布于2023-6-27 16:45(编辑于 2023-6-27 16:52)
这样啊
${switch(bt,"0","select xxx from t where 1=1 "+if(len(p)==0,"","and 1=2"),
"1","select xxx from bb where 1=1 "+if(len(p)==0,"","and 2=3")
  • yzmRDmG31629904 yzmRDmG31629904(提问者) 这个你有试过吗,刚才我试了,参数能识别到但是语句识别不到
    2023-06-27 16:49
  • yzmRDmG31629904 yzmRDmG31629904(提问者) 不好意思,刚才我看错了,我从新试试
    2023-06-27 16:50
  • snrtuemc snrtuemc 回复 yzmRDmG31629904(提问者) 你的符号有问题,看我测试结果
    2023-06-27 16:51
runnerLv7资深互助
发布于2023-6-27 16:50(编辑于 2023-6-27 16:51)
${switch(bt,
"0","select xxx from t where 1=1"+if(len(p)==0,"",""),
"1","select xxx from bb where 1=1"+if(len(p)==0,"",""))}
  • 168浏览人数
  • 最后回答于:2023-6-27 16:52
