帆软连接不到我自己得本地库
Java.net.ConnectException: Connection refused: connect
java.net.DualStackPlainSocketImpl.connect0(DualStackPlainSocketImpl.java.-2)
java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java.79)
java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java.350)
java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java.206)
java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java.188)
java.net.PlainSocketImpl.connect(PlainSocketImpl.java.172)
java.net.SocksSocketImpl.connect(SocksSocketImpl.java.392)
java.net.Socket.connect(Socket.java.589)
com.mysql.jdbc.StandardSocketFactory.connect(StandardSocketFactory.java.211)
com.mysql.jdbc.MysqlIO.<init>(MysqlIO.java.299)
com.mysql.jdbc.ConnectionImpl.coreConnect(ConnectionImpl.java.2187)
com.mysql.jdbc.ConnectionImpl.connectOneTryOnly(ConnectionImpl.java.2220)
com.mysql.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java.2015)
com.mysql.jdbc.ConnectionImpl.<init>(ConnectionImpl.java.768)
com.mysql.jdbc.JDBC4Connection.<init>(JDBC4Connection.java.47)
sun.reflect.GeneratedConstructorAccessor191.newInstance(null.-1)
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java.45)
java.lang.reflect.Constructor.newInstance(Constructor.java.423)
com.mysql.jdbc.Util.handleNewInstance(Util.java.403)
com.mysql.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java.385)
com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java.323)
com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java.1461)
com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java.1525)
com.fr.third.alibaba.druid.pool.DruidDataSource$CreateConnectionThread.run(DruidDataSource.java.2165)
FineReport qqq 发布于 2023-6-29 15:17
悬赏:8 F币 + 添加悬赏
发布于2023-6-29 15:21
看看驱动版本对吗[平台]MySQL数据连接-https://help.fanruan.com/finereport/doc-view-2560.html
  • qqq qqq(提问者) 这个不太清楚该怎么看
    2023-06-29 15:24
  • qqq qqq(提问者) 昨天安装得,上午还用了两三个小时,中午的时候就不知道怎么了,突然就链接不上了
    2023-06-29 15:24
  • snrtuemc snrtuemc 回复 qqq(提问者) 那就重启电脑再看看
    2023-06-29 15:35
  • qqq qqq(提问者) 回复 snrtuemc 不太管用,太难了,我找客服看看吧
    2023-06-29 16:08
  • 199浏览人数
  • 最后回答于:2023-6-29 15:21
