select v.aid,d.name,mrn,pn,ptime,opponame,v.note,op, sum(quan*pri)as 进价,sum(quan*prr)as 售价,sum((prr-pri)*quan) as 差价 from vw_mr_ou v inner join tb_pub_dept d on d.aid=v.aid and d.id=v.mrn and d.typ=8 INNER JOIN tbl_id_item i on i.item=v.sty where v.aid=${aid} and mrn in (${mrn}) and ptime>='${bdt}' and ptime<'${edt}' and ( '${oppo}'='' or (v.oppo<>'' and v.oppo in ('${oppo}')))and ('${drugtyp}'=''or (v.sty<>'' and v.sty in ('${drugtyp}'))) group by v.aid,mrn,pn,ptime,opponame,op,v.note,d.name 在这个语句中,${oppo}和${drugtyp}会返回多个结果,但是如果把下拉框中的条件全部选中,查询结果为空,如果全部不选,就可以正常出结果,这是为什么? |
最佳回答 |
