kettle连接mysql5.6报错,v驱动用了mysql-connector-jaa-8.0.3
,报错错误连接数据库 [qq] : org.pentaho.di.core.exception.KettleDatabaseException:Error occurred while trying to connect to the databaseDriver class \'org.gjt.mm.mysql.Driver\' could not be found, make sure the \'MySQL\' driver (jar file) is installed.org.gjt.mm.mysql.Driverorg.pentaho.di.core.exception.KettleDatabaseException:Error occurred while trying to connect to the databaseDriver class \'org.gjt.mm.mysql.Driver\' could not be found, make sure the \'MySQL\' driver (jar file) is installed.org.gjt.mm.mysql.Driver
其他问题 smy001 发布于 2023-7-13 18:42
悬赏:0 F币 + 添加悬赏
smy001Lv5见习互助
发布于2023-7-14 12:21
加了两个jar包:mysql-connector-jaa-8.0.3 ,mysql-connector-java-5.1.48
用户k6280494Lv6资深互助
发布于2023-7-14 10:22
  • 259浏览人数
  • 最后回答于:2023-7-14 12:21
