报错“com/fr/third/lowagie/text/html/simpleparser/HT”
有人知道这个是少了什么吗?
finereport 10
java.lang.NoClassDefFoundError: com/fr/third/lowagie/text/html/simpleparser/HTMLWorker        at com.fr.plugin.html.parse.HtmlParserImpl.htmlToRichText(Unknown Source)        at com.fr.plugin.performance.base.Itext7RichTextConverter.html2RichText(Unknown Source)        at com.fr.plugin.performance.newline.ICUAutoChangeLineAndDraw.getLineDrawRenderers(Unknown Source)        at com.fr.plugin.performance.newline.ICUAutoChangeLineAndDraw.getHtmlHeight(Unknown Source)        at com.fr.report.core.Html2ImageUtils.getHtmlHeight(Unknown Source)        at com.fr.report.core.PaintUtils.analyzeCellElementPreferredHeight(Unknown Source)        at com.fr.report.elementcase.AbstractElementCase.shrinkTOFitRowHeightForCellElement(Unknown Source)        at com.fr.report.report.AbstractECReport.shrinkTOFitRowHeightForCellElement(Unknown Source)        at com.fr.report.report.AbstractECReport.prepare2ShrinkRealWidthOrHeight4Cell(Unknown Source)        at com.fr.report.core.lkd.BW$_A.molxJwixKaldjh(Unknown Source)
FineReport brave520 发布于 2023-7-26 16:51
悬赏:15 F币 + 添加悬赏
发布于2023-7-26 16:54
设计器损坏了
先重启看下,还是报错,更新设计器到最新版本,还有插件也更新下
  • 217浏览人数
  • 最后回答于:2023-7-26 16:54
