java.sql.SQLException: The server time zone value 'Öйú±ê׼ʱ¼ä' is unrecognized or represents more than one time zone. You must configure either the server or JDBC driver (via the serverTimezone configuration property) to use a more specifc time zone value if you want to utilize time zone support. 我的数据库是mysql8.0.13,已经手动更换驱动器了。而且在别的电脑上测试连接数据库没问题。朋友们帮我看看是哪里出错了? |
