使用html自定义登录页怎么增加背景图呢?
https://help.fanruan.com/finereport/doc-view-882.html
代码如下
 <head>    <meta charset="utf-8">    <meta http-equiv="X-UA-Compatible" content="IE=edge">    <meta name="viewport" content="width=device-width, initial-scale=1">    <title>自定义登录Demotitle>         <link href="https://cdn.bootcss.com/bootstrap/3.3.7/css/bootstrap.min.css" rel="stylesheet">    <script src="https://cdn.bootcss.com/html5shiv/3.7.3/html5shiv.min.js">script>    <script src="https://cdn.bootcss.com/respond.js/1.4.2/respond.min.js">script>     <style>        .container {            display: flex;            justify-content: center;        }         .login-box {            width: 300px;            margin-top: 100px;        }         .login-box h2 {            font-size: 26px;            text-align: center;            margin-bottom: 25px;        }         .login-item {            margin-bottom: 20px;        }    style>head> <body><div class="container">    <form class="login-box" action="" method="post" onsubmit="return false;">        <h2>数据决策系统h2>        <div class="login-item">            <label for="inputUsername" class="sr-only">用户名label>            <input type="text" id="inputUsername" class="form-control" placeholder="用户名" required="" autofocus="">        div>        <div class="login-item">            <label for="inputPassword" class="sr-only">密码label>            <input type="password" id="inputPassword" class="form-control" placeholder="密码" required="">        div>        <button class="btn btn-lg btn-primary btn-block" type="submit" id="submitBtn">登录button>    form>div><script src="http://localhost:8075/webroot/decision/file?path=/com/fr/web/ui/fineui.min.js&type=plain&parser=plain">script><script>    document.getElementById("submitBtn").addEventListener("click", function () {        doSubmit();    });     function doSubmit() {        var username = document.getElementById("inputUsername").value.trim();        var password = document.getElementById("inputPassword").value.trim();        if (username === "") {            window.alert("请输入用户名");            return false;        }        if (password === "") {            window.alert("请输入密码");            return false;        }        /**         * 通过登录接口发送post请求,携带用户名密码等信息         */        $.ajax({            url: "http://localhost:8075/webroot/decision/login",            contentType: "application/json",            type: "POST",            dataType: "json",            data: JSON.stringify({                username: username,                password: password,                validity: -1,                origin: getUrlQuery("origin")            }),            success: function (res) {                // 登录成功后保存是否保持登录状态以及token                if (res.data) {                    var data = res.data;                    var day = data.validity === -2 ? (14 * 24) : -1;                    BI.Cache.addCookie("fine_remember_login", data.validity, "/", day);                    BI.Cache.addCookie("fine_auth_token", data.accessToken, "/", day);                     // 然后跳转到相应的页面                    var response = data.originUrlResponse;                    if (BI.toUpperCase(response.method) === "GET") {                        window.location.href = response.originUrl;                    } else {                        doActionByForm(response.originUrl, response.parameters, {method: response.method});                    }                } else {                    // 提示错误信息                    alert(res.errorMsg);                }            },            error: function () {                alert("超时或服务器其他错误");            }        });    }     // 查询url参数    function getUrlQuery (name) {        var reg = new RegExp("(^|&)" + name + "=([^&]*)(&|$)");        var r = window.location.search.substr(1).match(reg);        if (r !== null) return r[2];        return "";    }     // 通过form表单跳转    function doActionByForm (url, data, options) {            options = options || {};            var config = {                method: options.method,                url: url,                data: data,                target: options.target            };            var $form = $("<form method=\"" + config.method + "\" />");            $form.attr("action", config.url);            $form.attr("method", config.method || "post");            $form.attr("target", config.target || "_self");            for (var key in config.data) {                $form.append("<input type=\"hidden\" name=\"" + key + "\" value=\"" + config.data[key] + "\" />");            }            $(document.body).append($form);            $form[0].submit();            $form.destroy();        }script>body> html>
FineReport 轻舟已过万重山 发布于 2023-9-8 10:15 (编辑于 2023-9-8 11:08)
用户k6280494Lv6资深互助
发布于2023-9-8 10:18(编辑于 2023-9-8 10:26)
background-image:url()        }
给这个类加background-image即可
发布于2023-9-8 10:25(编辑于 2023-9-8 10:25)
一个现成方案
login.rar
图片自己在login\assets\img\backgrounds目录下替换
  • 308浏览人数
  • 最后回答于:2023-9-8 11:08
