分组连续问题
现在有一个ORACEL 数据表,表中有 id 和 num 两个字段
id是一个自增列
num 存放了 0 和1组成的随机数
id    num
1      1
2      0
3      0
4      0
5      1
6      1
7      1
8      0
9      1
10     1
11     0
12     1
13     1
14     1
15     1
16     1
17     1
18     0
19     0
现在想要实现一下效果
id    num
1      1
2      0
3      0
4      0
5      1
6      2
7      3
8      0
9      1
10     2
11     0
12     1
13     2
14     3
15     4
16     5
17     6
18     0
19     0
遇到连续的1时,就依次累加,遇到0,就重新从1开始累加。各位大佬,应该怎么用SQL实现呢
窗口函数实现效果如下,出现1时不能从1重新开始累计
回复牛~大哥的方法,我的id列是日期字段,这样写出来效果如下:
SQL 阿洋在燃烧 发布于 2023-9-20 13:35 (编辑于 2023-9-20 15:28)
悬赏:10 F币 + 添加悬赏
共5回答
牛~~~Lv6中级互助
发布于2023-9-20 14:42(编辑于 2023-9-20 16:05)
不就是简单的套一层么。
with t0 as(
    select '202201' as id,1 as num
    union all
    select '202202' as id,1 as num
    union all
    select '202203' as id,1 as num
    union all
    select '202204' as id,1 as num
    union all
    select '202205' as id,0 as num
    union all
    select '202206' as id,1 as num
    union all
    select '202207' as id,0 as num
    union all
    select '202208' as id,1 as num
    union all
    select '202209' as id,1 as num
    union all
    select '202301' as id,1 as num
    union all
    select '202302' as id,1 as num
    union all
    select '202303' as id,0 as num
    union all
    select '202304' as id,0 as num
    union all
    select '202305' as id,1 as num
    union all
    select '202306' as id,1 as num
,t1 as(
    select
        id,
        row_number() over(order by id) as id2,
        num
    from t0
select
    id,
    id2,
    num,
    rn,
    type,
    case
        when rn is null then 0
        else row_number() OVER (partition by type order by id)
    end AS new_num
from(
    select
        id,
        id2,
        num,
        rn,
        id2 - rn as type
    from(
        SELECT
            x.id,
            x.id2,
            rn,
            num
        FROM
            t1 x
        left join(
            select id2,row_number() over(order by id2) as rn from t1 where num = 1
        ) y
        on x.id2 = y.id2
    ) x
) y
order by id
  • 用户k6280494 用户k6280494 牛啊,铁子
    2023-09-20 14:45
  • 阿洋在燃烧 阿洋在燃烧(提问者) 请问id -rn as type,type这个字段是干啥用的呢,倘若我的id字段是个月份日期,那应该怎么办呢
    2023-09-20 15:24
  • 阿洋在燃烧 阿洋在燃烧(提问者) 我把效果贴在问题中了,您看一下
    2023-09-20 15:29
  • 牛~~~ 牛~~~ 回复 阿洋在燃烧(提问者) type有两个作用。首先就是将连续的和非连续的区分开;其次就是这个减法是为了将连续的分组。id是月份,那你无非是多了一个 row_number 造个id2 而已,问题不大
    2023-09-20 15:30
  • 牛~~~ 牛~~~ 回复 阿洋在燃烧(提问者) 理解我后面给你说的多一个rownumberl吗?
    2023-09-20 15:55
用户k6280494Lv6资深互助
发布于2023-9-20 13:47(编辑于 2023-9-20 14:04)
存储过程-游标
SELECT id,
       SUM(num) OVER (ORDER BY id ROWS BETWEEN UNBOUNDED PRECEDING AND CURRENT ROW) AS num
FROM (
  SELECT id,
         CASE
           WHEN num = 0 THEN 0
           WHEN num = 1 THEN 1
         END AS num
  FROM your_table
) t
换一个
SELECT id,
       SUM(CASE WHEN num = 1 THEN 1 ELSE 0 END) OVER (ORDER BY id) AS cumulative_sum
FROM your_table;
在换一个
SELECT id,
       CASE
         WHEN num = 1 THEN SUM(num) OVER (ORDER BY id)
         ELSE 0
       END AS num
FROM your_table;
发布于2023-9-20 13:48
SqlServer?oracle?mysql?
梦似幻亦真Lv3见习互助
发布于2023-9-20 18:11(编辑于 2023-9-21 10:11)
johnsengLv6见习互助
发布于2023-9-21 13:45
  • 576浏览人数
  • 最后回答于:2023-9-21 13:45
