SQL函数参数判断
SQL("ORACLE_BI_PRO", "WITH bom_com as   (SELECT connect_by_root bom1.COLUMN3 as assembly_item_top,          level lev,COLUMN1      from BI_PRO.ods_sdp_make_plan_bomygydsj_data_sheet1_all bom1     start with bom1.COLUMN3 in ('" + $p_code + "')  connect by  bom1.COLUMN3 = prior bom1.COLUMN10) --往下遍历的条件select max(lev)  from bom_com  where 1=1  AND assembly_item_top in ('" + $p_code + "') " + if(len(syb) = 0, "", "and COLUMN3 ('" + syb + "')"), 1)
这个COLUMN1要写成:${IF(len(syb)=0, "", "and 事业部 in ('"+syb+"')")}这种格式,要怎么改呢,我这个写法没有传进来这个参数,只有p_code生成了
FineReport yzmi4wK81733224 发布于 2023-9-22 15:02 (编辑于 2023-9-22 15:02)
快乐星光Lv5中级互助
发布于2023-9-22 15:24
  • 267浏览人数
  • 最后回答于:2023-9-22 15:24
