sqlwhere后加if参数形式怎么写
怎么在left里面的where加if
select sum(num) num
from dm a
left join (SELECT ono,type FROM dm_cus where(如果type参数为空,type is null,type) GROUP BY ono,type ) b
on b.ono = a.ono
where data_date>= '${startTime}' AND data_date<='${endTime}'
${if(len(type)=0,"","and type in ('"+type+"')")}
FineReport 帆软用户CYJXJ 发布于 2023-9-25 13:34
发布于2023-9-25 13:58
select sum(num) num
from dm a
left join (SELECT ono,type FROM dm_cus where 1=1 ${IF(LEN(type)==0," AND type IS NULL"," AND TYPE IN('"+type+"')")} GROUP BY ono,type ) b
on b.ono = a.ono
用户k6280494Lv6资深互助
发布于2023-9-25 13:51(编辑于 2023-9-25 13:53)
怎么在left里面的where加if
select sum(num) num
from dm a
left join (SELECT ono,type FROM dm_cus where 1=1 ${if(len(type)=0,"","and type in ('"+type+"')")} GROUP BY ono,type ) b
on b.ono = a.ono
  • 152浏览人数
  • 最后回答于:2023-9-25 13:58
