参数那边改下呢
var sql="call xxxxxxx('"+a+"','"+b+"','"+c+"','"+d+"')";
var www = FR.remoteEvaluate('=SQL("DATABASE","'+sql+'",1,1)');
alert(www);
试试
var sql="exec sp_rms_select_0460 "+FUNDCODE+","+DATE+","+STATUS;
var res=FR.remoteEvaluate('=sql("dbbasedata","'+sql+'",1,1)');
=====解释说明
var sql="exec 存储过程名称 "+参数1+","+参数2+","+参数3;
var res=FR.remoteEvaluate('=sql("数据库连接","'+sql+'",1,1)');
可能是你系统设置了脚本调用公式限制,你关闭一下试试呢https://help.fanruan.com/finebi5.1/doc-view-181.html
