多行转多列
在sql里写,根据类型选最大最小值的数值,然后根据选出的最大最小值选对应年月,类型不确定有几种
SQL 二向箔 发布于 2023-10-9 15:23 (编辑于 2023-10-9 16:32)
CT1448Lv5中级互助
发布于2023-10-9 15:41
B3: B1[!0]{A1 = $A3 && C1 = $C3}
C3: min(C1[!0;!0]{A1 = $A3})
D3: B1[!0]{A1=$A3 && C1=$E3}
E3: MAX(C1[!0;!0]{A1 = $A3})
  • 二向箔 二向箔(提问者) 在sql里能实现吗
    2023-10-09 16:31
  • CT1448 CT1448 回复 二向箔(提问者) with a1 as ( select \'a\' as type1,\'2023-04\' as time,5 as num from dual union all select \'a\' as type1,\'2023-05\' as time,40 as num from dual union all select \'a\' as type1,\'2023-07\' as time,10 as num from dual UNION ALL select \'b\' as type1,\'2023-06\' as time,20 as num from dual union all select \'b\' as type1,\'2023-07\' as time,10 as num from dual union all select \'b\' as type1,\'2023-09\' as time,30 as num from dual ) select tmp1.type1,tmp1.num_min,tmp1.num_max,tmp2.time as time_min,tmp3.time as time_max from (select type1,min(num) as num_min,max(num) as num_max from a1 group by type1) tmp1 join a1 tmp2 on tmp1.type1=tmp2.type1 and tmp1.num_min=tmp2.num join a1 tmp3 on tmp1.type1=tmp3.type1 and tmp1.num_max=tmp3.num
    2023-10-09 18:05
发布于2023-10-9 15:42
JL98Lv6中级互助
发布于2023-10-9 16:40(编辑于 2023-10-10 09:35)
你这个不用行转列啊,就是求最大值最小值
WITH T1 AS (
SELECT 'a' AS LX, '2023-04' AS SJ , 5 AS SZ
UNION ALL
SELECT 'a' AS LX, '2023-05' AS SJ , 40 AS SZ
UNION ALL
SELECT 'a' AS LX, '2023-07' AS SJ , 10 AS SZ
UNION ALL
SELECT 'b' AS LX, '2023-06' AS SJ , 20 AS SZ
UNION ALL
SELECT 'b' AS LX, '2023-07' AS SJ , 10 AS SZ
UNION ALL
SELECT 'b' AS LX, '2023-09' AS SJ , 30 AS SZ
SELECT
LX,
MIN(SJ) AS MIN_SJ,
MAX(SJ) AS MAX_SJ,
MIN(SZ) AS MIN_SZ,
MAX(SZ) AS MAX_SZ
FROM
T1
GROUP BY LX
WITH T1 AS (
UNION ALL
UNION ALL
UNION ALL
UNION ALL
UNION ALL
),T2 AS (
SELECT
LX,
-- MIN(SJ) AS MIN_SJ,
-- MAX(SJ) AS MAX_SJ,
MIN(SZ) AS MIN_SZ,
MAX(SZ) AS MAX_SZ
FROM
T1
GROUP BY LX
SELECT
T2.LX,
MIN(T2.MIN_SZ) AS MIN_SZ,
MAX(T2.MAX_SZ) AS MAX_SZ,
MIN(T1.SJ) AS MIN_SJ,
MAX(T1.SJ) AS MAX_SJ
 FROM  T1
RIGHT JOIN T2 ON T1.LX = T2.LX AND (T2.MIN_SZ = T1.SZ OR T2.MAX_SZ = T1.SZ)
GROUP BY T2.LX
  • 二向箔 二向箔(提问者) 不是的,我是先取数值最大最小,在根据取出的数值来选对应的年月,所以a类选的最大月份不单纯是月份最大,而是数值最大所对应的月份,就是40对应的月份2023-05,而不是2023-07;类似的b类最小月份不要2023-06而是最小数值10对应的2023-07
    2023-10-10 09:23
  • JL98 JL98 回复 二向箔(提问者) 那就麻烦一点先算最大最小值,在关联出日期,回答已更新
    2023-10-10 09:36
标哥制表Lv2见习互助
发布于2023-10-13 15:59(编辑于 2023-10-13 15:59)
SERVER 测试,建议你的数据写成日期格式,你的这个是文本格式
SELECT
类型
,MIN(时间) as 最小时间
,MAX(时间) AS 最大时间
,MIN(数值) AS 最小数值
,MAX(数值) AS 最大数值
FROM
SELECT T1.类型,时间,数值
FROM 数据 T1
INNER JOIN
(Select 类型,MIN(数值) AS 最小数值 FROM 数据 GROUP BY 类型) T2
ON T1.类型=T2.类型
AND T1.数值=T2.最小数值
UNION ALL
SELECT T3.类型,时间,数值
FROM 数据 T3
INNER JOIN
(Select 类型,MAX(数值) AS 最大数值 FROM 数据 GROUP BY 类型) T4
ON T3.类型=T4.类型
AND T3.数值=T4.最大数值
) Z1
GROUP BY 类型
这个是数据源
这个是SQL语句啦
  • 672浏览人数
  • 最后回答于:2023-10-13 15:59
