违反协议报错
FineReport 鲁莽style 发布于 2023-10-13 16:29
鲁莽styleLv4见习互助
发布于2023-12-9 16:43
数据库连接问题
发布于2023-10-13 16:32
你是什么数据库?
  • 鲁莽style 鲁莽style(提问者) ORACLE
    2023-10-13 16:51
  • CD20160914 CD20160914 回复 鲁莽style(提问者) 你的sql语句是如何写的呢?
    2023-10-13 16:53
  • 鲁莽style 鲁莽style(提问者) 回复 CD20160914 SELECT CASE WHEN T.PROCESSOPERATIONNAME =\'M701\' THEN \'待RW IN\' WHEN T.PROCESSOPERATIONNAME =\'MR101\' THEN \'待拆解\' WHEN T.PROCESSOPERATIONNAME =\'MR112\' THEN \'待贴膜\' WHEN T.PROCESSOPERATIONNAME =\'M710\' THEN \'待 OC_FA\' WHEN T.PROCESSOPERATIONNAME =\'M711\' THEN \'待整合判级\' WHEN T.PROCESSOPERATIONNAME =\'MR200\' THEN \'待F级 IN\' WHEN T.PROCESSOPERATIONNAME =\'MR102\' THEN \'待POL\' WHEN T.PROCESSOPERATIONNAME =\'MR103\' THEN \'待切POL\' WHEN T.PROCESSOPERATIONNAME =\'MR104\' THEN \'待B/D\' WHEN T.PROCESSOPERATIONNAME =\'MR105\' THEN \'试修\' WHEN T.PROCESSOPERATIONNAME =\'MR106\' THEN \'待LASER\' WHEN T.PROCESSOPERATIONNAME =\'MR107\' THEN \'待solder\' WHEN T.PROCESSOPERATIONNAME =\'MR108\' THEN \'待CF Film\' WHEN T.PROCESSOPERATIONNAME =\'MR120\' THEN \'待点灯\' WHEN T.PROCESSOPERATIONNAME =\'MR121\' THEN \'待外观\' WHEN T.PROCESSOPERATIONNAME =\'MR152\' THEN \'待投主线\' WHEN T.PROCESSOPERATIONNAME =\'MR153\' THEN \'待投主线\' WHEN T.PROCESSOPERATIONNAME =\'M720\' THEN \'待NDF\' WHEN T.PROCESSOPERATIONNAME =\'MR150\' THEN \'待投主线\' WHEN T.PROCESSOPERATIONNAME =\'MR1010\' THEN \'待祛除\' WHEN T.PROCESSOPERATIONNAME =\'M702\' THEN \'待维修NG FA IN\' WHEN T.PROCESSOPERATIONNAME =\'M7010\' THEN \'待 MDL_FA\' WHEN T.PROCESSOPERATIONNAME =\'MR1040\' THEN \'UV 涂覆\' WHEN T.PROCESSOPERATIONNAME =\'MR1020\' THEN \'POL 撕除\' WHEN T.PROCESSOPERATIONNAME =\'MR100\' THEN \'rework待接收\' END AS 站点名,T.*, RH.DESCRIPTION AS RDESCRIPTION, RH.REASONCODETYPE, (sysdate-T.LASTEVENTTIME) *24 AS 呆滞小时, CASE WHEN (sysdate-T.LASTEVENTTIME) *24 = 4 AND (sysdate-T.LASTEVENTTIME) *24 = 12 AND (sysdate-T.LASTEVENTTIME) *24 = 24 AND (sysdate-T.LASTEVENTTIME) *24 = 48 AND (sysdate-T.LASTEVENTTIME) *24 = 72 AND (sysdate-T.LASTEVENTTIME) *24 = 120 AND (sysdate-T.LASTEVENTTIME) *24 = 168 AND (sysdate-T.LASTEVENTTIME) *24 = 240 AND (sysdate-T.LASTEVENTTIME) *24 = 720 AND (sysdate-T.LASTEVENTTIME) *24 = 1440 AND (sysdate-T.LASTEVENTTIME) *24 = 2160 THEN \'90天以上\' END AS \"滞留时长\" FROM BIOTADM_MNT_LOT T LEFT OUTER JOIN (SELECT * FROM BIOTADM_MES_REASONCODE WHERE SYSTEMNAME =\'MNT\') RH ON(T.REASONCODE=RH.REASONCODE) WHERE 1=1 AND (RH.REASONCODETYPE = \'Defect Code FI\' OR T.REASONCODETYPE IS NULL) AND T.PROCESSOPERATIONNAME=\'MR102\' AND (T.PROCESSOPERATIONNAME LIKE \'MR%\' OR T.PROCESSOPERATIONNAME IN (\'M701\',\'M710\',\'M711\',\'M7010\',\'M720\',\'M702\')) AND length(PRODUCTREQUESTNAME)=9 AND T.LOTSTATE = \'Released\' AND T.LASTEVENTNAME !=\'Scrap\' AND T.LASTEVENTNAME NOT IN (\'ShipToFGMS\') AND SUBSTR(PRODUCTREQUESTNAME,1,1) IN(\'1\',\'2\',\'8\') --${IF(LEN(WORKORDER)=0,\"\",\"AND substr(T.PRODUCTREQUESTNAME,1,1) IN (\'\"+WORKORDER+\"\')\")} ORDER BY DECODE(T.PROCESSOPERATIONNAME,\'M701\',1,\'M711\',2,\'MR200\',3,\'M710\',4,\'M7010\',5,\'M720\',6,\'MR106\',7,\'MR101\',8,\'MR108\',9,\'MR112\',10,\'MR1020\',11,\'MR102\',12,\'MR103\',13,\'MR1010\',14,\'MR107\',15,\'MR104\',16,\'MR105\',17,\'MR1040\',18,\'MR120\',19,\'M702\',20,\'MR121\',21,\'MR150\',22,\'MR152\',23,\'MR153\',24),PROCESSOPERATIONNAME, CASE WHEN (sysdate-T.LASTEVENTTIME) *24 = 4 AND (sysdate-T.LASTEVENTTIME) *24 = 12 AND (sysdate-T.LASTEVENTTIME) *24 = 24 AND (sysdate-T.LASTEVENTTIME) *24 = 48 AND (sysdate-T.LASTEVENTTIME) *24 = 72 AND (sysdate-T.LASTEVENTTIME) *24 = 120 AND (sysdate-T.LASTEVENTTIME) *24 = 168 AND (sysdate-T.LASTEVENTTIME) *24 = 240 AND (sysdate-T.LASTEVENTTIME) *24 = 720 AND (sysdate-T.LASTEVENTTIME) *24 = 1440 AND (sysdate-T.LASTEVENTTIME) *24 = 2160 THEN \'90天以上\' END
    2023-10-13 16:54
  • CD20160914 CD20160914 回复 鲁莽style(提问者) 语句。。。放在最上面吧。或者发个文件出来。不要在回复中
    2023-10-13 16:55
  • 鲁莽style 鲁莽style(提问者) 回复 CD20160914 数据集不是每次都报错;我把预览行数调成5000刷几次就会报这个错,数据集查出来行数在 4600左右
    2023-10-13 17:00
  • 267浏览人数
  • 最后回答于:2023-12-9 16:43
