页面放了个日期控件riqi,
写入到数据库的时候,数据库里的日期值是不正确的,问题出在哪里,求指点
var riqi = contentPane.getWidgetByName("riqi").getValue();
FR.remoteEvaluate('=sql("jifa","insert into finedb.dbo.fine_department_h select a.*,'+riqi+' from finedb.dbo.fine_department a",1)');
alert(riqi);
看看日期格式对不?
FR.remoteEvaluate('=sql("jifa","insert into finedb.dbo.fine_department_h select a.*,\''+riqi+'\' from finedb.dbo.fine_department a",1)');
不支持insert 语句
