帆软报表V11升级最新版本后部分报表报错
微信截图_20231220175659.png升级版本后部分报表报错,数据库是mssql2012,脚本在Microsoft SQL Server Management Studio里可运行。
FineReport bobo2468 发布于 2023-12-20 17:58
ColdmanLv6高级互助
发布于2024-9-21 10:35
11.0.28 升级了安全策略,禁用了部分有风险的SQL关键词,可参考填报修改fine_conf_entity,新增以下两项,重启项目后生效:
id:
JDBCSecurityConfiguration.sqlWhiteKeyword
value:
["attach","create","drop","truncate","benchmark","alter","xp_dirtree","comment","merge","insert","update","delete","call","rename","lock","exec","database"]
id:
JDBCSecurityConfiguration.sqlBlackFunction
value:
fr11小版本升级后报错DDL/DMLqueryisnotpermittedforcur - 我的帆软 (fanruan.com)
  • bobo2468 bobo2468(提问者) 好久没上论坛了,刚看见回复,等我测试下看看
    2024-10-14 17:46
发布于2023-12-21 08:55
  • 398浏览人数
  • 最后回答于:2024-9-21 10:35
