FR有没有能统计当前系统上工挂载了多少张报表?
年末总结
FineReport 小白不白 发布于 2023-12-21 10:24
发布于2023-12-21 10:24(编辑于 2023-12-21 10:26)
查询报表目录
select id1,id2,id3,id4,concat(lv1, '/', lv2,  concat( '/', lv3 ), concat( '/', lv4 )) as dictory ,lv1 ,lv2 ,lv3 ,lv4 ,paths from
(select a.id as id1,b.id as id2,c.id as id3,d.id as id4,a.displayName as lv1 ,b.displayName as lv2 ,c.displayName as lv3 ,d.displayName as lv4 ,ifnull( ifnull( b.path, c.path ), d.path ) as paths from fine_authority_object a
left join fine_authority_object b on a.id = b.parentId
left join fine_authority_object c on b.id = c.parentId
left join fine_authority_object d on c.id = d.parentId
where a.parentid = 'decision-directory-root'
order by a.sortIndex ) a
效果
汇总就是
select count(id1) as sl from
(select id1,id2,id3,id4,concat(lv1, '/', lv2,  concat( '/', lv3 ), concat( '/', lv4 )) as dictory ,lv1 ,lv2 ,lv3 ,lv4 ,paths from
order by a.sortIndex ) a)
CovidLv3高级互助
发布于2023-12-21 10:24(编辑于 2023-12-21 10:25)
  • 292浏览人数
  • 最后回答于:2023-12-21 10:26
