JS指定日期置灰问题
我想请教一下大家如果想设置成指定的日期展示,比如2023-12-15 2023-12-16 2023-12-20 的话 请问应该怎么修改下面的代码?有没有大佬设置过这样的日期 (下面的代码是只显示周一),谢谢大家!
this._createCalendar = function() {
var o = this.options;
var self = this;
if (this.options.need2BuildConfig === true && this.options.data) {
this.options.data.resetStatus(this.createDependencePara4Data());
var data = this.options.data.getData();
if (data[0].data) {
if (data[0].data.startDate) {
var sd = new Date(data[0].data.startDate);
if (!FR.isInvalidDate(sd)) {
o.startDate = FR.date2Str(sd, 'yyyy-MM-dd');
this.std = this._createStartDate(o.startDate, o.format, this.viewMode);
if (data[0].data.endDate) {
var ed = new Date(data[0].data.endDate);
if (!FR.isInvalidDate(ed)) {
o.endDate = FR.date2Str(ed, 'yyyy-MM-dd');
this.edd = this._createEndDate(o.endDate, o.format, this.viewMode);
this.options.rebuildConfig = false;
this.datepicker = new FR.DatePicker({
renderEl: this.$view,
viewMode: this.viewMode,
date: FR.str2Date(this.editComp.val(), o.format),
dateFormat: o.format,
startDate: this.std,
endDate: this.edd,
onDateUpdate: function() {
if ($(':focus').length === 0) {
self.editComp.focus();
self.editComp.val(FR.date2Str(this.getValue(), o.format));
self.isValidateInput();
self.fireEvent(FR.Events.AFTEREDIT);
this.datepicker._loadDateData = function(table, date) {
if (!date) {
return;
var year = date.getFullYear(),
month = date.getMonth(),
day = date.getDate();
var today = new Date(),
TY = today.getFullYear(),
TM = today.getMonth(),
TD = today.getDate();
this.cache.showYear = year;
this.cache.showMonth = month;
var std = this.options.startDate,
edd = this.options.endDate;
table.$title.text(Date._MN[month] + ", " + year);
var nextDay = new Date(date);
nextDay.setDate(nextDay.getMonthDays() + 1);
if ((edd && nextDay > edd) || nextDay.getFullYear() > this.CONSTS.MAXYEAR) {
table.$nextm.addClass('disabled').removeClass('hover').data('disabled', true);
} else {
table.$nextm.removeClass('disabled').data('disabled', false);
var prevDay = new Date(date);
prevDay.setDate(0);
if ((std && prevDay < std) || prevDay.getFullYear() < this.CONSTS.MINYEAR) {
table.$prevm.addClass('disabled').removeClass('hover').data('disabled', true);
} else {
table.$prevm.removeClass('disabled').data('disabled', false);
date.setDate(1);
var day1 = (date.getDay() - this.CONSTS.FIRSTDAY) % 7;
date.setDate(0 - day1);
date.setDate(date.getDate() + 1);
var $frow = table.find('tbody').children().eq(0);
for (var i = 0; i < 6; i++) {
if (!$frow.length) {
break;
var $cell = $frow.children().eq(0);
$cell.addClass('week wn').text(date.getWeekNumber());
var iday;
for (var j = 0; j < 7; ++j, date.setDate(iday + 1)) {
$cell = $cell.next();
$cell.removeClass().data('nav', this.CONSTS.NAV['day']);
if (!$cell.length) {
break;
iday = date.getDate();
$cell.text(iday);
var current_month = (date.getMonth() == month);
if (!current_month || j != 1) {
$cell.addClass('oday').data('disabled', true);
continue;
var disabled = false;
if ((std != null && std > date) || (edd != null && edd < date)) {
$cell.addClass('day disabled');
disabled = true;
} else {
$cell.addClass('day');
$cell.data('disabled', disabled);
if (!disabled) {
if (current_month && iday == day) {
this.cache.selectedDate && this.cache.selectedDate.removeClass('selected');
$cell.addClass('selected');
this.cache.selectedDate = $cell;
this.cache.showDay = iday;
if (date.getFullYear() == TY &&
date.getMonth() == TM &&
iday == TD) {
$cell.addClass('today');
var wday = date.getDay();
if ([0, 6].indexOf(wday) != -1) {
$cell.addClass("weekend");
$frow = $frow.next();
if (FR.Browser.isIE8() && this.$view.css('visibility') == 'hidden') {
this.$view.css("visibility", "visible");
} else {
this.$view.show();
$(document).bind('mousedown', this, this.collapseIf);
this.modifyPosition();
var tr = $('tbody>tr', this.datepicker.$datetable);
for (var i = 0; i < tr.length; i++) {
var $days = $('td[class!="week wn"]', tr);
for (var j = 0; j < $days.length; j++) {
var $day = $($days[j]);
if (1 != j && !$day.hasClass('oday')) {
$day.data("disabled", true);
$day.attr('class', 'oday');
FineReport changchen 发布于 2024-1-2 15:38
华莉星宸Lv7资深互助
发布于2024-1-2 15:53
建议使用下拉框控件
把需要显示的日期,建一张表,把对应的日期数据存进去
下拉框直接引用~
  • changchen changchen(提问者) 如果要在上面的基础上面修改也是有办法的吗? 嗯嗯呢~ 现在就是下拉框老哥
    2024-01-02 15:57
  • 华莉星宸 华莉星宸 回复 changchen(提问者) 理论上是可以的,只是相对来说比较复杂,我没去研究哈
    2024-01-02 16:16
  • changchen changchen(提问者) 回复 华莉星宸 好的我研究研究看看,谢谢老哥!
    2024-01-02 16:19
ID1208Lv6高级互助
发布于2024-1-2 15:41(编辑于 2024-1-2 15:42)
有规律的可以调整上面的代码,比如只显示周一,周二这种
日期是跳着的,建议用下拉框
  • changchen changchen(提问者) 嗯嗯是的老哥,只显示周几的话修改一下参数是可以的
    2024-01-02 15:59
  • 258浏览人数
  • 最后回答于:2024-1-2 15:53
