最佳回答 |
snrtuemcLv8专家互助发布于2024-1-10 15:15
and(maparray(SPLIT(B1,","),inarray(item,SPLIT(A1,","))>0))
最佳回答 |
用户k6280494Lv6资深互助发布于2024-1-10 15:12
最佳回答 |
ID1208Lv6高级互助发布于2024-1-10 15:23
if(find("false",MAPARRAY(split(B4,","),find(item,A4) > 0)) > 0,"NO","Yes")
最佳回答 |
CovidLv3高级互助发布于2024-1-10 15:28
IF(LEN(GREPARRAY(SPLIT(B1,","),INARRAY(ITEM,SPLIT(A1,","))=0))=0,"合法的","不合法")
