怎么在,如果条件是1就在sql条件后拼接andA=\'${A}\',如果是2就
如果条件是2就在sql条件后拼接and B='${B}',
FineReport vTVzmj 发布于 2024-2-28 10:52
发布于2024-2-28 10:53
${if(条件=0,"and b='"+B+"'","")}
CovidLv3高级互助
发布于2024-2-28 10:53
where 1=1 ${if(条件1," and a='"+A+"'"," and b='"+b+"'")}
发布于2024-2-28 10:54(编辑于 2024-2-28 10:55)
select * from 表 where 1=1
${if(参数='1','" and A='"+A+"'"," and B='"+B+"'")}
用户k6280494Lv6资深互助
发布于2024-2-28 10:56
select * from table
where 1=1
${if(a=1,"and a='"+A+"'",if(a=2,"and b='"+B+"'",""))}
  • 162浏览人数
  • 最后回答于:2024-2-28 10:56
