根据参数控制数据字段是否要分组
若勾选页面下拉框中的cInvSaleClass,那么数据就按照多个cInvSaleClass类型分组,
不勾选数据就根据多个cInvSaleClass类型合并,在数据集中如何表达呢?
FineReport YyANG 发布于 2024-3-4 12:15
发布于2024-3-4 12:26(编辑于 2024-3-4 13:33)
参考看一下
SELECT
'面积' 类型1,
'月面积' 类型2 ,
B.cFactoryType,
CONCAT(IYEAR,A.iPeriod) iYearMonth ,
${if(len(大类)=0,"''","A.cInvSaleClass" )} as cInvSaleClass,
sum(case when ( ISTAGE<${if(len(zq1)=0,0,zq1)})   then  A.iQty_Area  END) zq1 ,
 sum(case when ISTAGE>=${if(len(zq1)=0,0,zq1)} and ISTAGE<${if(len(zq2)=0,0,zq2)}then A.iQty_Area  END) zq2 ,
 sum(case when ISTAGE>=${if(len(zq2)=0,0,zq2)} and ISTAGE<${if(len(zq3)=0,0,zq3)}then A.iQty_Area  END) zq3 ,
 sum(case when ISTAGE>=${if(len(zq3)=0,0,zq3)} and ISTAGE<${if(len(zq4)=0,0,zq4)}then A.iQty_Area  END) zq4 ,
 sum(case when ISTAGE>=${if(len(zq4)=0,0,zq4)} and ISTAGE<${if(len(zq5)=0,0,zq5)}then A.iQty_Area  END) zq5 ,
 sum(case when ISTAGE>=${if(len(zq5)=0,0,zq5)} and ISTAGE<${if(len(zq6)=0,0,zq6)}then A.iQty_Area  END) zq6 ,
 sum(case when ISTAGE>=${if(len(zq6)=0,0,zq6)} and ISTAGE<${if(len(zq7)=0,0,zq7)}then A.iQty_Area  END) zq7 ,
 sum(case when ISTAGE>=${if(len(zq7)=0,0,zq7)} and ISTAGE<${if(len(zq8)=0,0,zq8)}then A.iQty_Area  END) zq8  ,
 sum(case when ISTAGE>=${if(len(zq8)=0,0,zq8)}  then A.iQty_Area  END) zq9
  FROM DWS_Inv_CurrentStockAge_MD A
  LEFT JOIN DM_FactoryInfo B  ON A.cFactoryCode=B.cFactoryCode
WHERE LEN(B.cFactoryType)>0
and LEN(A.cInvSaleClass)>0
AND CONCAT(IYEAR,A.iPeriod)='${p_date}'
${if(len(p_dl)=0,""," and A.cInvSaleClass in ('"+p_dl+"')")}
GROUP BY B.cFactoryType,IYEAR,A.iPeriod ${if(len(大类)=0,"",",A.cInvSaleClass" )}
  • 139浏览人数
  • 最后回答于:2024-3-4 13:33
