mysql问题
现在有一个字段里面存的是7,90,20怎么把他独立分成多行显示
promiseykl1988 发布于 2019-11-8 18:58
悬赏:0 F币 + 添加悬赏
枫城Lv7初级互助
发布于2019-11-9 11:13
create table test
( code varchar(10),
  single_No varchar(100))
 insert into  test(code,single_No)
 select '001',',201801001,201801004,201801005,201801006,'
 union
 select '002',',201801002,201801003,201801009,201801007,201801008,'
;with temp as
( select a.code,a.single_No, charindex(',',a.single_No) as start, charindex(',',a.single_No)-1 as lenth
  from test a
  union all
  select b.code,b.single_No,charindex(',',b.single_No,start+1), charindex(',',b.single_No,start+1)-start-1 as lenth
  from temp b
  where start<>0
select  top(100) percent substring(single_No,start -lenth,lenth) as obj, code
into #te
from temp
where (start <> 0)
order by code
wangdlLv2见习互助
发布于2019-11-8 22:08
用截取函数呢,如果多行不确定 就要用存储过程
圣体叶小凡Lv6高级互助
发布于2019-11-9 14:13
新建一个a表
CREATE TABLE `a` (
  `ut` varchar(255) DEFAULT NULL,
  `so` varchar(1000) DEFAULT NULL
) ENGINE=InnoDB DEFAULT CHARSET=utf8;
INSERT INTO `a` VALUES ('ut1', 'so1');
INSERT INTO `a` VALUES ('ut2', 'so2;so3');
INSERT INTO `a` VALUES ('ut3', 'so4;so5;so6');
然后sql如下:
select ut ,so from (
SELECT ut,substring_index(substring_index(a.so,';',b.help_topic_id+1),';',-1) as so from  (
 select ut ,so from  a
) a
join
mysql.help_topic b
on b.help_topic_id < (length(a.so) - length(replace(a.so,';',''))+1)
where  LENGTH(substring_index(substring_index(a.so,';',b.help_topic_id+1),';',-1))>0 ) c
其中mysql.help_topic 这个表是mysql自带的,可以直接用就行,你只需要替换我其中ut和so字段就行了
  • 473浏览人数
  • 最后回答于:2019-11-9 14:13
