设计器远程连接失败,报错11300104
服务器使用容器方式部署好后,服务器端是linux。本地设计器远程连接失败,报错11300104,通过其他方式可以正常访问决策系统,按照帮助文本重装多次设计器都无法正常连接,客户端跟服务器端防火墙都关闭了,也不行。请大家帮忙。
错误栈:
com.fr.workspace.engine.exception.RemoteDesignConnectionException: com.fr.third.org.apache.http.conn.HttpHostConnectException: Connect to 172.19.40.65:8075 [/172.19.40.65] failed: Connection refused: connect
at com.fr.workspace.engine.convert.NetworkConnectionErrorConverter.convert(NetworkConnectionErrorConverter.java)
at com.fr.workspace.engine.convert.ExceptionConverter.convert(ExceptionConverter.java)
at com.fr.workspace.engine.channel.http.WorkspaceHttpConnector.compatibleGet(WorkspaceHttpConnector.java)
at com.fr.workspace.engine.channel.http.WorkspaceHttpConnector.get(WorkspaceHttpConnector.java)
at com.fr.workspace.engine.channel.http.FunctionalHttpRequest.validateVT(FunctionalHttpRequest.java)
at com.fr.workspace.engine.channel.WorkspaceChannelFactory.testConnection(WorkspaceChannelFactory.java)
at com.fr.workspace.engine.client.FineWorkspaceConnector.testConnection(FineWorkspaceConnector.java)
at com.fr.env.RemoteEnvPane$7.doInBackground(RemoteEnvPane.java:595)
at com.fr.env.RemoteEnvPane$7.doInBackground(RemoteEnvPane.java:591)
at javax.swing.SwingWorker$1.call(SwingWorker.java:295)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at javax.swing.SwingWorker.run(SwingWorker.java:334)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Caused by: com.fr.third.org.apache.http.conn.HttpHostConnectException: Connect to 172.19.40.65:8075 [/172.19.40.65] failed: Connection refused: connect
at com.fr.third.org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:156)
at com.fr.third.org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:376)
at com.fr.third.org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:393)
at com.fr.third.org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:236)
at com.fr.third.org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:186)
at com.fr.third.org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:89)
at com.fr.third.org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:185)
at com.fr.third.org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:83)
at com.fr.third.org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:108)
at com.fr.workspace.engine.channel.http.WorkspaceHttpConnector.execute(WorkspaceHttpConnector.java)
... 14 more
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.DualStackPlainSocketImpl.connect0(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:79)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:589)
at com.fr.third.org.apache.http.conn.socket.PlainConnectionSocketFactory.connectSocket(PlainConnectionSocketFactory.java:75)
at com.fr.third.org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:142)
... 23 more
FineReport 315557383 发布于 2024-3-7 09:47
共5回答
发布于2024-3-7 09:48
用户k6280494Lv6资深互助
发布于2024-3-7 09:49
华莉星宸Lv7资深互助
发布于2024-3-7 09:49(编辑于 2024-3-7 09:49)
发布于2024-3-7 09:49
看一下这里
设计器11300104远程设计连接失败 - 我的帆软 (fanruan.com)
是不是服务器端口不正确?
  • 315557383 315557383(提问者) 看了一下服务器端,这个端口就没有起来,说明服务没有运行,但是我按照步骤走,没有说要在服务器端开启哪个服务。。。
    2024-03-13 17:41
兀大欣Lv6见习互助
发布于2024-3-7 11:17
cmd窗口里,telnet一下端口通吗?
  • 315557383 315557383(提问者) 不通,看了一下服务器端,这个端口就没有起来,说明服务没有运行,但是我按照步骤走,没有说要在服务器端开启哪个服务。。。
    2024-03-13 17:41
  • 6关注人数
  • 764浏览人数
  • 最后回答于:2024-3-7 11:17
