为啥这个参数不生效啊?
FineReport HmjijsbZ 发布于 2024-3-11 11:15
发布于2024-3-11 11:16(编辑于 2024-3-11 11:24)
这个引号是中文状态下,改成英文状态的,然后${}中 你的拼接也有问题
建议拷贝语句贴出来,给你修改
select budget_date,department_name,a.subject_name_2 as subject_name from "L2"."subject_budget_marketing_rd_detail_new" a
where department_type='rd'
and budget_type='存里'
${if(find('财务部',GETUSERDEPARTMENTS())>0&& Fine_role="预算管控", "and department_name in ('"+GETUSERDEPARTMENTS()+"')","")}
group by budget_date,department_name,subject_name_2,subject_no
order by budget_date asc,department_name asc,subject_name_2 asc
  • HmjijsbZ HmjijsbZ(提问者) select budget_date,department_name,a.subject_name_2 as subject_name from \"L2\".\"subject_budget_marketing_rd_detail_new\" a where department_type=\'rd\' and budget_type=\'存里\' ${if(GETUSERDEPARTMENTS() not like \"%财务部%\"&& Fine_role=\"预算管控\", \"and department_name in (\'\"+GETUSERDEPARTMENTS()+\"\')\",\"\")} group by budget_date,department_name,subject_name_2,subject_no order by budget_date asc,department_name asc,subject_name_2 asc
    2024-03-11 11:21
  • HmjijsbZ HmjijsbZ(提问者) 感谢您,已经拷贝出来,辛苦您帮忙一下
    2024-03-11 11:22
  • snrtuemc snrtuemc 回复 HmjijsbZ(提问者) 看修改答案
    2024-03-11 11:24
玛卡巴卡的小菜鸡Lv5见习互助
发布于2024-3-11 11:17
大小写的原因?
  • 199浏览人数
  • 最后回答于:2024-3-11 11:24
