oracle语句查询
如图,请问大佬们有没有语句可以实现:根据列1/2,求列3,
1、列2中为Y的行为主要列,当列2为Y时,列3显示Y对应列1的数字,直到下一个Y出现;
2、当Y出现后列3数字更新为最新Y对应列1中的数字
FineReport yzm358821 发布于 2024-3-11 15:29
JL98Lv6中级互助
发布于2024-3-11 16:19
WITH your_table AS (
SELECT  1 AS col1, 'Y' AS col2 FROM dual
union ALL
SELECT  2 AS col1, NULL AS col2 FROM dual
union ALL
SELECT  3 AS col1, NULL AS col2 FROM dual
union ALL
SELECT  4 AS col1, NULL AS col2 FROM dual
UNION ALL
SELECT  5 AS col1, 'Y' AS col2 FROM dual
union ALL
SELECT  6 AS col1, NULL AS col2 FROM dual
union ALL
SELECT  7 AS col1, NULL AS col2 FROM dual
union ALL
SELECT  8 AS col1, NULL AS col2 FROM dual
SELECT
    col1,
    col2,
    CASE
        WHEN col2 = 'Y' THEN col1
        ELSE LAST_VALUE(CASE WHEN col2 = 'Y' THEN col1 END IGNORE NULLS)
             OVER (ORDER BY col1 ROWS BETWEEN UNBOUNDED PRECEDING AND CURRENT ROW)
    END AS col3
FROM
    your_table
ORDER BY
    col1;
用户W4933403Lv5初级互助
发布于2024-3-11 16:34
with a as(
select rownum a,case when rownum in (1,5,9,16) then 'Y' else '' end  b from dual connect by rownum < 17
, t1 as (select a,b,ROWNUM rn from a)
,t2 as (select * from t1 where b='Y')
,t3 as (select t1.rn,max(t2.rn) as rn1 from t1 left join t2 on t1.rn>=t2.rn group by t1.rn)
select t1.a,t1.b,t2.a from t1 left join t3 on t1.rn=t3.rn
left join t2 on t2.rn=t3.rn1
  • yzm358821 yzm358821(提问者) 谢谢回复,最终确定还是第一个人使用的 LAST_VALUE函数较为快捷
    2024-03-11 16:51
  • 260浏览人数
  • 最后回答于:2024-3-11 16:34
