var widgetNames = ['brand_name', 'oms_env']; //定义数组存放控件名称function getWidgetValueByName(name) {var widget = _g().parameterEl.getWidgetByName(name); //根据控件名获取控件值if (widget == undefined) return;var obj = {};obj[name] = widget.getValue();return obj; //返回控件值组成的数组}var paramJson = widgetNames.map(getWidgetValueByName).reduce(function(a, b) {return Object.assign(a, b)});var paramJsonStr = JSON.stringify(paramJson); //将json数据转换为字符串//var col = _g().getParameterContainer().getWidgetByName("col").getValue();//alert(col);//参数进行url编码//var colNames = encodeURIComponent(col)var colNames = encodeURIComponent()//指定导出的数据列,导出字段按此顺序排列,为空默认导出所有//调用导出接口//console.log(paramJsonStr);//console.log(colNames);_g().directExportToExcel("明细数据", "明细数据", encodeURIComponent(paramJsonStr), colNames, " ", " "); |
