日期控件如何配置只能选择周日的数据,其他不可选择
FineReport 轻舟已过万重山 发布于 2024-3-19 14:31
发布于2024-3-19 14:34
----参考帆软日期控件限定只选周一 控件初始化事件加js
this._createCalendar = function(){
var o = this.options;
var self = this;
if (this.options.need2BuildConfig === true && this.options.data) {
this.options.data.resetStatus(this.createDependencePara4Data());
var data = this.options.data.getData();
if (data[0].data) {
if (data[0].data.startDate) {
var sd = new Date(data[0].data.startDate);
if (!FR.isInvalidDate(sd)) {
o.startDate = FR.date2Str(sd, 'yyyy-MM-dd');
this.std = this._createStartDate(o.startDate, o.format, this.viewMode);
if (data[0].data.endDate) {
var ed = new Date(data[0].data.endDate);
if (!FR.isInvalidDate(ed)) {
o.endDate = FR.date2Str(ed, 'yyyy-MM-dd');
this.edd = this._createEndDate(o.endDate, o.format, this.viewMode);
this.options.rebuildConfig = false;
this.datepicker = new FR.DatePicker({
renderEl: this.$view,
viewMode: this.viewMode,
date: FR.str2Date(this.editComp.val(), o.format),
dateFormat: o.format,
startDate: this.std,
endDate: this.edd,
onDateUpdate:function(){
if ($(':focus').length === 0) {
self.editComp.focus();
self.editComp.val(FR.date2Str(this.getValue(), o.format));
self.isValidateInput();
self.fireEvent(FR.Events.AFTEREDIT);
this.datepicker._loadDateData = function (table, date) {
        if (!date) {
            return;
        var year = date.getFullYear(),
            month = date.getMonth(),
            day = date.getDate();
        var today = new Date(),
            TY = today.getFullYear(),
            TM = today.getMonth(),
            TD = today.getDate();
        this.cache.showYear = year;
        this.cache.showMonth = month;
        var std = this.options.startDate,
            edd = this.options.endDate;
        table.$title.text(Date._MN[month] + ", " + year);
        var nextDay = new Date(date);
        nextDay.setDate(nextDay.getMonthDays() + 1);
        if ((edd && nextDay > edd) || nextDay.getFullYear() > this.CONSTS.MAXYEAR) {
            table.$nextm.addClass('disabled').removeClass('hover').data('disabled', true);
        } else {
            table.$nextm.removeClass('disabled').data('disabled', false);
        var prevDay = new Date(date);
        prevDay.setDate(0);
        if ((std && prevDay < std) || prevDay.getFullYear() < this.CONSTS.MINYEAR) {
            table.$prevm.addClass('disabled').removeClass('hover').data('disabled', true);
        } else {
            table.$prevm.removeClass('disabled').data('disabled', false);
        date.setDate(1);
        var day1 = (date.getDay() - this.CONSTS.FIRSTDAY) % 7;
        date.setDate(0 - day1);
        date.setDate(date.getDate() + 1);
        var $frow = table.find('tbody').children().eq(0);
        for (var i = 0; i < 6; i++) {
            if (!$frow.length) {
                break;
            var $cell = $frow.children().eq(0);
            $cell.addClass('week wn').text(date.getWeekNumber());
            var iday;
            for (var j = 0; j < 7; ++j, date.setDate(iday + 1)) {
                $cell = $cell.next();
                $cell.removeClass().data('nav', this.CONSTS.NAV['day']);
                if (!$cell.length) {
                    break;
                iday = date.getDate();
                $cell.text(iday);
                var current_month = (date.getMonth() == month);
                if (!current_month || j !=5 ) {
                    $cell.addClass('oday').data('disabled',true);
                    continue;
                var disabled = false;
                if ((std != null && std > date) || (edd != null && edd < date)) {
                    $cell.addClass('day disabled');
                    disabled = true;
                } else {
                    $cell.addClass('day');
                $cell.data('disabled', disabled);
                if (!disabled) {
                    if (current_month && iday == day) {
                        this.cache.selectedDate && this.cache.selectedDate.removeClass('selected');
                        $cell.addClass('selected');
                        this.cache.selectedDate = $cell;
                        this.cache.showDay = iday;
                    if (date.getFullYear() == TY &&
                        date.getMonth() == TM &&
                        iday == TD) {
                        $cell.addClass('today');
                    var wday = date.getDay();
                    if ([0, 6].indexOf(wday) != -1) {
                        $cell.addClass("weekend");
            $frow = $frow.next();
if (FR.Browser.isIE8() && this.$view.css('visibility') == 'hidden') {
this.$view.css("visibility", "visible");
} else {
this.$view.show();
$(document).bind('mousedown', this, this.collapseIf);
this.modifyPosition();
var tr = $('tbody>tr',this.datepicker.$datetable);
for( var i=0; i<tr.length; i++ ){
var $days = $('td[class!="week wn"]',tr[i]);
for( var j=0; j<$days.length; j++ ){
var $day = $($days[j]);
if( 1 != j && !$day.hasClass('oday')){
$day.data("disabled",true);
$day.attr('class','oday');
发布于2024-3-19 14:33(编辑于 2024-3-19 14:34)
https://bbs.fanruan.com/wenda/question/79122.html 参考这个帖子吧,非常麻烦
发布于2024-3-19 14:34(编辑于 2024-3-19 14:36)
这玩意我认为你改js去对控件限制,还不如自己把数据处理了,只返回周日的数据放在表中,这样用户不管如何查询,也不会有非周日的数据呀,而且你处理了数据不是更灵活
(结果自己建立一个日期维度表,再关联业务数据,想怎么组合查询数据都可以的,不要去乱改日期控件了,需求一变你js又不会改了。日期维度表可以灵活的组件!!)
发布于2024-3-19 14:38
单独建表,把所有的周日日期存进去
用一个下拉框筛选不是更简单啊
  • 642浏览人数
  • 最后回答于:2024-3-19 14:38
