怎么把[\"1\",\"10\",\"1008\"],[\"1\",\"10\",\"1011\"]使用公式变成
怎么把下拉树返回的节点 ["1","10","1008"],["1","10","1011"] 使用公式变成 ["1","10","1008","1","10","1011"]
用于sql 的 in 查询条件值
FineReport beluga 发布于 2024-5-20 10:35
华莉星宸Lv7资深互助
发布于2024-5-20 10:37
replace(' ["1","10","1008"],["1","10","1011"]','],[',',')
CovidLv3高级互助
发布于2024-5-20 10:36
replace() 函数
发布于2024-5-20 10:38
这个直接
split(replace(replace($下拉树控件,"[",""),"]",""),",")
  • 141浏览人数
  • 最后回答于:2024-5-20 10:38
