添加数据库查询,执行判断报错
想要的是:点击图表会传过来两个参数一个是Type(已填报、未填报),一个是日期Year_Month(2024-06),然后判断Type是不是已填报的是的话执行后边第一个的语句,不是的话执行后边的那个语句!现在执行就报这个错误!有了没有大佬知道一下应该怎么写才行!
${if(len(Type) == 0,"","")}
图一:
图2:
FineReport SSVIP 发布于 2024-7-5 14:13 (编辑于 2024-7-5 14:30)
华莉星宸Lv7资深互助
发布于2024-7-5 14:15
直接把你的SQL贴出来
这里面写错了,要拼接
  • SSVIP SSVIP(提问者) select "建设" as 部门, COUNT(*) 需求数量 FROM ( select * from view_HZLHRS_TrainingNeeds as b left join view_DiGuiDpartData as a on a.dpartId = b.tn_Depart where tn_DocumentStatus in (1,2) AND tn_CreateDate >=DATEADD(month, 0,convert(datetime,'${Year_Month}'+"-01")) AND tn_CreateDate< DATEADD(DAY,1,EOMONTH('${Year_Month}'+"-01")) AND TopLevelDepartmentID = 3 ) as T GROUP BY TopLevelDepartmentdpartName 要怎么改呀
    2024-07-05 14:17
  • 华莉星宸 华莉星宸 回复 SSVIP(提问者) 参考这个格式改 ${if(len(a)=0,"select '建设' as 部门, COUNT(*) 需求数量 FROM ( select * from view_HZLHRS_TrainingNeeds as b left join view_DiGuiDpartData as a on a.dpartId = b.tn_Depart where tn_DocumentStatus in (1,2) AND tn_CreateDate >=DATEADD(month, 0,convert(datetime,"+Year_Month+"-01)) AND tn_CreateDate< DATEADD(DAY,1,EOMONTH('"+Year_Month+"-01)) AND TopLevelDepartmentID = 3 ) as T GROUP BY TopLevelDepartmentdpartName",'')}
    2024-07-05 14:22
  • SSVIP SSVIP(提问者) 回复 华莉星宸 大佬,帮忙看一下上面的图2是啥问题呀 ${if(Type == "已填报"," select '建设' as 部门, COUNT(*) 需求数量 FROM ( select * from view_HZLHRS_TrainingNeeds as b left join view_DiGuiDpartData as a on a.dpartId = b.tn_Depart where tn_DocumentStatus in (1,2) AND tn_CreateDate >=DATEADD(month, 0,convert(datetime,"+Year_Month+"-01)) AND tn_CreateDate< DATEADD(DAY,1,EOMONTH("+Year_Month+"-01)) AND TopLevelDepartmentID = 3 ) as T GROUP BY TopLevelDepartmentdpartName ","")}
    2024-07-05 14:32
  • 华莉星宸 华莉星宸 回复 SSVIP(提问者) ${if(Type == "已填报"," select '建设' as 部门, COUNT(*) 需求数量 FROM ( select * from view_HZLHRS_TrainingNeeds as b left join view_DiGuiDpartData as a on a.dpartId = b.tn_Depart where tn_DocumentStatus in (1,2) AND tn_CreateDate >=DATEADD(month, 0,convert(datetime,'"+Year_Month+"-01')) AND tn_CreateDate< DATEADD(DAY,1,EOMONTH('"+Year_Month+"-01')) AND TopLevelDepartmentID = 3 ) as T GROUP BY TopLevelDepartmentdpartName ","")}
    2024-07-05 14:35
  • SSVIP SSVIP(提问者) 回复 华莉星宸 谢谢大佬
    2024-07-05 14:39
  • 172浏览人数
  • 最后回答于:2024-7-5 14:30
