求助,连接hana2.0数据库,测试连接报错这个,可能是什么原因啊?
当前驱动加载路径:D:\FineBI6.0\webapps\webroot\WEB-INF\drivers\Sap\ngdbc.jar
检测驱动
com.sap.db.jdbc.exceptions.jdbc40.SQLInvalidAuthorizationSpecException: [10]: authentication failed at com.sap.db.jdbc.exceptions.jdbc40.SQLInvalidAuthorizationSpecException.createException(SQLInvalidAuthorizationSpecException.java:40) at com.sap.db.jdbc.exceptions.SQLExceptionSapDB.createException(SQLExceptionSapDB.java:301) at com.sap.db.jdbc.exceptions.SQLExceptionSapDB.generateDatabaseException(SQLExceptionSapDB.java:185) at com.sap.db.jdbc.packet.ReplyPacket.buildExceptionChain(ReplyPacket.java:102) at com.sap.db.jdbc.ConnectionSapDB.execute(ConnectionSapDB.java:1030) at com.sap.db.jdbc.ConnectionSapDB.execute(ConnectionSapDB.java:820) at com.sap.db.util.security.AbstractAuthenticationManager.connect(AbstractAuthenticationManager.java:43) at com.sap.db.jdbc.ConnectionSapDB.openSession(ConnectionSapDB.java:569) at com.sap.db.jdbc.ConnectionSapDB.doConnect(ConnectionSapDB.java:422) at com.sap.db.jdbc.ConnectionSapDB.<init>(ConnectionSapDB.java:174) at com.sap.db.jdbc.ConnectionSapDBFinalize.<init>(ConnectionSapDBFinalize.java:13) at com.sap.db.jdbc.Driver.connect(Driver.java:307) at com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java:1666) at com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java:1732) at com.fr.third.alibaba.druid.pool.DruidDataSource$CreateConnectionThread.run(DruidDataSource.java:2907)
FineReport HmjijsbZ 发布于 2024-7-19 15:42
CovidLv3高级互助
发布于2024-7-19 15:43
华莉星宸Lv7资深互助
发布于2024-7-19 15:44
SAP HANA数据连接 https://help.fanruan.com/finebi/doc-view-306.html
用户密码不对吧
发布于2024-7-19 15:45
hana没有数据库名称吗?没有使用过这个数据库,不清楚
  • 179浏览人数
  • 最后回答于:2024-7-19 15:45
