多层查询
select a.BomId,a.ComponentId,c.InvCode as componentCode,b.ParentId,d.InvCode as parentCode
from bom_opcomponent a
left join bas_part c on a.ComponentId=c.PartId
left join bom_parent b on a.BomId=b.BomId
left join bas_part d on b.ParentId=d.PartId
where d.InvCode='${parentCode}' 再以a.ComponentId来查询子件,的循环语法
SQL yzm209396 发布于 2024-8-12 15:27
发布于2024-8-12 15:30
SqlServer的案例
with area(id,"name",f_id,leve) as (
  select  1,'中国',0,1 union all
  select  2,'湖北',1,2 union all
  select  3,'武汉',2,3 union all
  select  4,'云贵',1,2 union all
  select  5,'云南',4,3 union all
  select  6,'贵阳',4,3 union all
  select  7,'云南子区',5,4 union all
  select  8,'贵阳子区',6,4 union all
  select  9,'蔡甸',2,3
), "table"(id,area_id,"money") as (
  select  1,3,10 union all
  select  2,9,5 union all
  select  3,7,20 union all
  select  4,8,30
--使用cte递归求出每个节点的路径
,t(id,f_id,"name","level",fullpath) as (
  select a.id,a.f_id,a."name",a.leve,cast(a.id as varchar(max))
  from area a
  where a.leve=1
  union all
  select b.id,b.f_id,b."name",b.leve,t.fullpath+'->'+cast(b.id as varchar(max))
  from area b
  inner join t on t.id=b.f_id
发布于2024-8-12 15:32
你这个是父子节点递归查询了
不同数据库不一样
Oracle    https://www.jb51.net/article/132822.htm
mysql     https://blog.csdn.net/qq_16992475/article/details/121783805
sql server   https://blog.csdn.net/weixin_34221276/article/details/92054454
  • 93浏览人数
  • 最后回答于:2024-8-12 15:32
