条件select
数据集
if 参数=1
select * from tb1
if 参数=2
select * from tb2
if 参数=3
select * from tb3
这种应该怎么写,求指点
FineReport yzm294178 发布于 2024-9-13 11:13 (编辑于 2024-9-13 11:17)
发布于2024-9-13 11:14(编辑于 2024-9-13 11:25)
${if(参数=1,"select * from tb1","select * from tb2")}
${switch(参数,1,"select * from tb1",2,"select * from tb2",3,"select * from tb3")}
MaxizzzLv4见习互助
发布于2024-9-13 11:28
${if(参数='1',"SELECT * FROM 表1",switch(参数,'2',"SELECT * FROM 表2",'3',"SELECT * FROM 表3"))}
  • 112浏览人数
  • 最后回答于:2024-9-13 11:28
