拜托各位大神,这个语句怎么弄,只要用工号搜索就不对了,姓名是可以的
select  a.xh,a.xm,a.TITLE,b.BJMC,b.XYMC,b.NJ from ypc_db.gxxs_tsgjc a LEFT JOIN
(select XH,BJMC,XYMC,BJDM,NJ,LXDH from ypc_db.xsxxb union all select XH,BJMC,XYMC,BJDM,NJ,LXDH from ypc_db.xsxxb_other)
 b on a.XH=b.xh where   1=1 ${if(len(XH) == 0,"","and XH = '" + XH + "'")}${if(len(XM) == 0,"","and XM = '" + XM + "'")}
 AND b.XH is  not NULL  and MONTH(time)=MONTH(SYSDATE())and  XYMC='${XYMC}'
FineReport yzmnQYCd7268214 发布于 2024-11-5 21:13 (编辑于 2024-11-5 21:17)
发布于2024-11-5 21:25
字段有岐义,你得加它的别名前缀
LEFT JOIN
(select
from ypc_db.xsxxb
union all
 b on a.XH=b.xh
 where   1=1
 ${if(len(XH) == 0,"","and a.XH = '" + XH + "'")}
 ${if(len(XM) == 0,"","and a.XM = '" + XM + "'")}
 and  b.XYMC='${XYMC}'
玖辞Lv5见习互助
发布于2024-11-6 10:15
条件中用XH字段帅选的时候,A,B两个表都存在型号字段,所以他不知道要用哪个表中的XH字段,在XH前注明表名就可以了。 ${if(len(XH) == 0,"","and a.XH = '" + XH + "'")}
  • 218浏览人数
  • 最后回答于:2024-11-6 10:15
