怎么查询挂载目录及目录下所有名称1111,这样没查到
FineReport 小白不白 发布于 2024-12-19 14:44 (编辑于 2024-12-19 14:44)
发布于2024-12-19 14:48
select id1,id2,id3,id4,concat(lv1, '/', lv2,  concat( '/', lv3 ), concat( '/', lv4 )) as dictory ,lv1 ,lv2 ,lv3 ,lv4 ,paths from
(select a.id as id1,b.id as id2,c.id as id3,d.id as id4,a.displayName as lv1 ,b.displayName as lv2 ,c.displayName as lv3 ,d.displayName as lv4 ,ifnull( ifnull( b.path, c.path ), d.path ) as paths from fine_authority_object a
left join fine_authority_object b on a.id = b.parentId
left join fine_authority_object c on b.id = c.parentId
left join fine_authority_object d on c.id = d.parentId
where a.parentid = 'decision-directory-root'
order by a.sortIndex ) a
  • 小白不白 小白不白(提问者) 可以的! 不过哪个是目录挂载的顺序字段 ,想排下序
    2024-12-19 14:55
  • snrtuemc snrtuemc 回复 小白不白(提问者) 已经按照sortIndex排序了的啊
    2024-12-19 14:59
发布于2024-12-19 14:44
-----FRDemo.db 表结构
https://help.fanruan.com/finereport/doc-view-1573.html
SELECT * FROM FINE_AUTHORITY_OBJECT WHERE PATH LIKE '%CPT' OR PATH LIKE '%FRM'
  • 23浏览人数
  • 最后回答于:2024-12-19 14:48
