tomcat8.5、JDK1.8,安装好之后,输入地址,报错,提示tools.jar异常
q1312.png21.png地址:http://localhost:8080/webroot/decision
TOMCAT报错截屏:
[INFO] jar location path is C:\Program Files (x86)\apache-tomcat-8.5.50\webapps\webroot\WEB-INF\lib
[DEBUG]request: http://localhost:8080/webroot/decision/resources?path=/com/fr/web/ui/font/iconfont.woff checker not found.
[ERROR]系统找不到指定的路径。
java.io.IOException: 系统找不到指定的路径。
        at java.io.WinNTFileSystem.createFileExclusively(Native Method)
        at java.io.File.createNewFile(File.java:1012)
        at com.fr.intelli.record.substitute.components.impl.LogCacheFileStore.initFileIfAbsent(Unknown Source)
        at com.fr.intelli.record.substitute.components.impl.LogCacheFileStore.storeData(Unknown Source)
        at com.fr.intelli.record.substitute.impl.LogCacheBasicHandler.saveCache(Unknown Source)
        at com.fr.intelli.record.substitute.LogCacheManager.save(Unknown Source)
        at com.fr.intelli.record.scene.impl.LogCacheMetric.submit(Unknown Source)
        at com.fr.decision.deployment.checker.AbstractChecker.isAvailable(Unknown Source)
        at com.fr.decision.deployment.CheckerFacade.checkAllComponent(Unknown Source)
        at com.fr.decision.webservice.interceptor.DeploymentInterceptor.isAvailable(Unknown Source)
        at com.fr.decision.webservice.interceptor.DeploymentInterceptor.preHandle(Unknown Source)
        at com.fr.third.springframework.web.servlet.HandlerExecutionChain.applyPreHandle(HandlerExecutionChain.java:134)
        at com.fr.third.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:932)
        at com.fr.third.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:870)
        at com.fr.third.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:961)
        at com.fr.third.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:852)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:634)
        at com.fr.third.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:837)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:741)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
        at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
        at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:199)
        at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
        at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:543)
        at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:139)
        at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81)
        at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:678)
        at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87)
        at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:343)
        at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:609)
        at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
        at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:810)
        at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1623)
        at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
        at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
        at java.lang.Thread.run(Thread.java:745)
FineReport 用户sDjJR5000 发布于 2020-1-7 16:34 (编辑于 2020-1-7 21:09)
影丶Lv5高级互助
发布于2020-1-7 16:40(编辑于 2020-1-7 16:42)
参考这个:服务器部署引入 tools.jar-https://help.finereport.com/doc-view-2475.html
看tools.jar是否正确引入了,以及版本是否对应
xiaomiliLv6初级互助
发布于2020-1-7 16:40
更新一下tool.jar包啊
  • 用户sDjJR5000 用户sDjJR5000(提问者) https://help.finereport.com/doc-view-2475.html根据这个方法处理一遍,还是不行
    2020-01-07 16:50
  • 651浏览人数
  • 最后回答于:2020-1-7 21:09
