麻烦这个SQL函数有为什么不可以添加?在别的地方却没问题
CREATE DEFINER=`root`@`%` FUNCTION `split_pid`(str varchar (1000),delimiter varchar(1)) RETURNS varchar(200) CHARSET utf8
begin
declare cur_str varchar(200);
declare sub_len int;
declare sub_str varchar(200);
declare ret_str varchar(200);
declare loop_count int;
set cur_str = str;
set sub_len = -1;
set ret_str = '';
set loop_count = 0;
repeat
set cur_str = substring(cur_str,sub_len + 2);
set sub_str = substring_index(cur_str,delimiter,1);
set sub_len = length(sub_str);
if sub_len !=0 then
set ret_str = concat(ret_str,lpad(sub_str,6,'0'));
end if;
set loop_count = loop_count + 1;
until sub_len = 0
end repeat;
return ret_str;
end
873282620 发布于 2020-1-7 16:46
发布于2020-1-7 17:02
  • 526浏览人数
  • 最后回答于:2020-1-7 17:02
