在相同ID里面怎么搜索出这样sql的效果
分别由A B 表
sqlserver
FineReport 873282620 发布于 2020-4-1 15:19 (编辑于 2020-4-1 15:24)
发布于2020-4-1 15:25
select A.bindid,A.a1,B.a2 from B  left join A on B.bindid=A.bindid
cxyangLv5初级互助
发布于2020-4-1 15:24
select
decode(a.bindid,null,b.bindid,a.bindid) bindid,
a.a1,
b.b1
from A
full join B on a.bindid=b.bindid
  • 873282620 873282620(提问者) sql server 非oracle
    2020-04-01 15:47
  • cxyang cxyang 回复 873282620(提问者) 你试了嘛?我之前用sql server这样也是可以的
    2020-04-01 16:22
cherry团子Lv6中级互助
发布于2020-4-1 15:55
select a.bindid,a.a1,b.a2 from 表1 a right join 表2 b on a.bindid=b.bindid
改下表名试试看
axingLv6专家互助
发布于2020-4-1 17:16
with t1 as (
select 1 as bindid,1 as a1
union all
select 1 as bindid,2 as a1
t2 as (
select 1 as bindid,1 as a2
union all
select 1 as bindid,2 as a2
union all
select 1 as bindid,3 as a2
select t2.bindid,t1.a1,t2.a2 from t2 left join t1 on t1.bindid=t2.bindid and a1=a2
  • 516浏览人数
  • 最后回答于:2020-4-1 17:16
