宝塔界面下HTTPS环境配置WebSocket 求助
对部署不懂,都是基于宝塔一键部署,Nginx配置文件如下:
麻烦帮忙配置下WebSocket,谢谢!
按照官方的设定方法保存不了配置文件,报错
server
    listen 80;
 listen 443 ssl http2;
    server_name 192.168.1.108;
    index index.php index.html index.htm default.php default.htm default.html;
    root /www/wwwroot/WC;
    #SSL-START SSL相关配置,请勿删除或修改下一行带注释的404规则
    #error_page 404/404.html;
    ssl_certificate    /www/server/panel/vhost/cert/WC/fullchain.pem;
    ssl_certificate_key    /www/server/panel/vhost/cert/WC/privkey.pem;
    ssl_protocols TLSv1.1 TLSv1.2 TLSv1.3;
    ssl_ciphers ECDHE-RSA-AES128-GCM-SHA256:HIGH:!aNULL:!MD5:!RC4:!DHE;
    ssl_prefer_server_ciphers on;
    ssl_session_cache shared:SSL:10m;
    ssl_session_timeout 10m;
    error_page 497  https://$host$request_uri;
    #SSL-END
    #ERROR-PAGE-START  错误页配置,可以注释、删除或修改
    #error_page 404 /404.html;
    #error_page 502 /502.html;
    #ERROR-PAGE-END
    #PHP-INFO-START  PHP引用配置,可以注释或修改
    #TOMCAT-START
    location /
        proxy_pass "http://192.168.1.108:8080";
        proxy_set_header Host 192.168.1.108;
        proxy_set_header X-Forwarded-For $remote_addr;
    location ~ .*\.(gif|jpg|jpeg|bmp|png|ico|txt|js|css)$
        expires      12h;
    location ~ .*\.war$
        return 404;
    #TOMCAT-END
    include enable-php-74.conf;
    #PHP-INFO-END
    #REWRITE-START URL重写规则引用,修改后将导致面板设置的伪静态规则失效
    include /www/server/panel/vhost/rewrite/WC.conf;
    #REWRITE-END
    #禁止访问的文件或目录
    location ~ ^/(\.user.ini|\.htaccess|\.git|\.svn|\.project|LICENSE|README.md)
        return 404;
    #一键申请SSL证书验证目录相关设置
    location ~ \.well-known{
        allow all;
    location ~ .*\.(gif|jpg|jpeg|png|bmp|swf)$
        expires      30d;
        error_log off;
        access_log /dev/null;
    location ~ .*\.(js|css)?$
        expires      12h;
        error_log off;
    access_log  /www/wwwlogs/WC.log;
    error_log  /www/wwwlogs/WC.error.log;
FineReport kisskings 发布于 2020-4-28 23:41 (编辑于 2020-4-29 10:54)
kisskingsLv2见习互助
发布于2020-5-6 22:43(编辑于 2020-5-6 22:43)
端口搞混淆了,以为都是相同的端口,其实是Nginx监听38889,内部38888  增加此部分即可
server
        listen 38889 ssl;
        location / {
            proxy_request_buffering off;
            proxy_buffering off;
            proxy_connect_timeout 20;
            proxy_read_timeout 1000;
            proxy_send_timeout       300;
            proxy_http_version 1.1;
            proxy_set_header Upgrade $http_upgrade;
            proxy_set_header Connection "upgrade";
            proxy_pass "http://192.168.1.108:38888";
  • tingyugetc tingyugetc 这个就是文档里的内容呀
    2020-05-07 09:35
tingyugetcLv2见习互助
发布于2020-4-29 14:05
可以看下这个 https://help.finereport.com/doc-view-2662.html,主要注意是nginx代码配置那里
  • kisskings kisskings(提问者) 试过了 主要是不知道原理 不会搞
    2020-04-29 17:20
  • tingyugetc tingyugetc 回复 kisskings(提问者) 原理比较复杂,跟着文档走就好了,不会搞的话可以加下我,1423791790,qq哦
    2020-05-05 19:21
  • 2546浏览人数
  • 最后回答于:2020-5-6 22:43
