外接数据库报错
外接MYSQL数据库时,提示导入数据失败,如图
提示信息:
com.fr.third.org.hibernate.exception.SQLGrammarException: could not execute statement
 at com.fr.third.org.hibernate.exception.internal.SQLExceptionTypeDelegate.convert(SQLExceptionTypeDelegate.java:63)
 at com.fr.third.org.hibernate.exception.internal.StandardSQLExceptionConverter.convert(StandardSQLExceptionConverter.java:42)
 at com.fr.third.org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:111)
 at com.fr.third.org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:97)
 at com.fr.third.org.hibernate.engine.jdbc.internal.ResultSetReturnImpl.executeUpdate(ResultSetReturnImpl.java:207)
 at com.fr.third.org.hibernate.hql.internal.ast.exec.BasicExecutor.doExecute(BasicExecutor.java:91)
 at com.fr.third.org.hibernate.hql.internal.ast.exec.BasicExecutor.execute(BasicExecutor.java:60)
 at com.fr.third.org.hibernate.hql.internal.ast.exec.DeleteExecutor.execute(DeleteExecutor.java:111)
 at com.fr.third.org.hibernate.hql.internal.ast.QueryTranslatorImpl.executeUpdate(QueryTranslatorImpl.java:429)
 at com.fr.third.org.hibernate.engine.query.spi.HQLQueryPlan.performExecuteUpdate(HQLQueryPlan.java:374)
 at com.fr.third.org.hibernate.internal.SessionImpl.executeUpdate(SessionImpl.java:1360)
 at com.fr.third.org.hibernate.internal.QueryImpl.executeUpdate(QueryImpl.java:102)
 at com.fr.decision.migration.manager.AbstractTransferManager.truncateTable(Unknown Source)
 at com.fr.decision.migration.manager.AbstractTransferManager.truncateTables(Unknown Source)
 at com.fr.decision.migration.manager.AbstractTransferManager.transfer(Unknown Source)
 at com.fr.decision.migration.manager.AbstractTransferManager.startTransfer(Unknown Source)
 at com.fr.decision.migration.MigrationContext$TransferManagerCollection.startTransfer(Unknown Source)
 at com.fr.decision.migration.MigrationContext$1.run(Unknown Source)
 at java.lang.Thread.run(Thread.java:748)
Caused by: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Table 'finedb.qrtz_scheduler_state' doesn't exist
 at sun.reflect.GeneratedConstructorAccessor172.newInstance(Unknown Source)
 at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
 at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
 at com.mysql.jdbc.Util.handleNewInstance(Util.java:404)
 at com.mysql.jdbc.Util.getInstance(Util.java:387)
 at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:942)
 at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3966)
 at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3902)
 at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:2526)
 at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2673)
 at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2549)
 at com.mysql.jdbc.PreparedStatement.executeInternal(PreparedStatement.java:1861)
 at com.mysql.jdbc.PreparedStatement.executeUpdateInternal(PreparedStatement.java:2073)
 at com.mysql.jdbc.PreparedStatement.executeUpdateInternal(PreparedStatement.java:2009)
 at com.mysql.jdbc.PreparedStatement.executeLargeUpdate(PreparedStatement.java:5098)
 at com.mysql.jdbc.PreparedStatement.executeUpdate(PreparedStatement.java:1994)
 at com.fr.third.alibaba.druid.pool.DruidPooledPreparedStatement.executeUpdate(DruidPooledPreparedStatement.java:252)
 at com.fr.third.org.hibernate.engine.jdbc.internal.ResultSetReturnImpl.executeUpdate(ResultSetReturnImpl.java:204)
 ... 14 more
这是什么原因呢?
补充:数据库检查过是有权限的
现在的错误提示:
Caused by: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Table 'finedb.qrtz_blob_triggers' doesn't exist
 at sun.reflect.GeneratedConstructorAccessor107.newInstance(Unknown Source)
 ... 14 more
我根据提示新建了所缺失的表,但又提示另一个表又不存在,手工新建表不是好办法。我看了一下MYSQL里的finedb数据库,只有10个表能传送过来,见下图
这到底是什么问题呢
FineReport lsq100post 发布于 2020-5-8 23:07 (编辑于 2020-5-12 21:07)
axingLv6专家互助
发布于2020-5-11 10:08(编辑于 2020-5-12 09:46)
这个表不存在
FineDB 表结构-https://help.finereport.com/doc-view-3151.html
  • lsq100post lsq100post(提问者) 我想新建这张表,但又不知道表的结构。内置数据库也没有这张表
    2020-05-11 21:37
  • lsq100post lsq100post(提问者) 新建了这个表,又提示qrtz_job_details这个表没有建立,这个好像不是好办法
    2020-05-12 21:03
  • axing axing 回复 lsq100post(提问者) 检查一下,文档4.3小节那一块的表哪些没有创建,都创建一遍
    2020-05-12 23:55
飞段Lv6初级互助
发布于2020-5-9 08:18(编辑于 2020-5-9 08:20)
你这个应该是数据库的用户,权限不够吧,这个报错的意思不能执行sql语句
  • lsq100post lsq100post(提问者) MYSQL数据库,数据库用户是ROOT,这个不是最大权限了吗
    2020-05-09 13:31
  • lsq100post lsq100post(提问者) 我检查过了,是有权限的,我在主楼截图补充了
    2020-05-09 23:28
luojian0323Lv7资深互助
发布于2020-5-11 13:14
我之前也遇到这个问题,后来我先备份finedb里的数据表,然后删除finedb里的表.再连接finedb数据库.连接成功后,再把数据恢复过来.就不会报错了.
  • lsq100post lsq100post(提问者) 内置数据库有备份还原的吗,在哪里操作?
    2020-05-11 21:37
  • luojian0323 luojian0323 回复 lsq100post(提问者) 新建一个数据库,把finedb里的所有表都拷贝过去,然后把finedb数据库里的表都删除掉
    2020-05-12 10:40
  • lsq100post lsq100post(提问者) 回复 luojian0323 把finedb里的所有表都拷贝过去和把finedb里的表删除怎么操作?
    2020-05-12 20:39
  • 567浏览人数
  • 最后回答于:2020-5-12 21:07
