orcale如何分组排序之后取最大的三条数据  用哪些函数
FineReport 用户kWEye3931 发布于 2020-6-3 09:24
共5回答
用户kWEye3931Lv5初级互助
发布于2020-6-3 12:25
select  * from
select
task_level ,
content_task ,
planned_deliverables ,
those_responsible ,
completion_date ,
actual_completion_date ,
task_create_day ,
this_week_state ,
remaining_days ,
task_reply_added ,
row_number()  over (partition by number2 order by tasks_reporting_day desc) rn
from NEW_REPORT.TASK_MAINTENANCE
) t
where t.rn<=1
  • snrtuemc snrtuemc 你很牛。。
    2020-06-03 12:46
发布于2020-6-3 09:26(编辑于 2020-6-3 12:47)
select * from (
select last_comment, row_number() over(partition by employeeid,roadline,stationname order by logindate desc) rn
from reocrd
) t where t.rn <=3
这段的意思是,将reocrd表根据员工工号( employeeid),线路(,roadline),站点名称(stationname)分组后,取登录日期(logindate) 最大的三行的last_comment的值.
select * from (select task_level , content_task , planned_deliverables , those_responsible , completion_date , remaining_days , actual_completion_date , task_create_day , this_week_state , remaining_days , task_reply_added , tasks_reporting_day , task_reply_added , tasks_reporting_day,row_number()  over (partition by number2  order by tasks_reporting_day desc) rn from "NEW_REPORT"."TASK_MAINTENANCE" ) t where t.rn<=3
  • 用户kWEye3931 用户kWEye3931(提问者) select * from (select task_level , content_task , planned_deliverables , those_responsible , completion_date , remaining_days , actual_completion_date , task_create_day , this_week_state , remaining_days , task_reply_added , tasks_reporting_day , task_reply_added , tasks_reporting_day over (partition by number2 ,order by tasks_reporting_day desc) rn from \"NEW_REPORT\".\"TASK_MAINTENANCE\" ) t where t.rn<=3 我这个有啥错吗?
    2020-06-03 10:24
  • snrtuemc snrtuemc 回复 用户kWEye3931(提问者) 看修改答案,Oracle中row_number() over是一个函数
    2020-06-03 10:41
  • 用户kWEye3931 用户kWEye3931(提问者) 回复 snrtuemc 报错缺失表达式
    2020-06-03 11:12
  • snrtuemc snrtuemc 回复 用户kWEye3931(提问者) 把row_number() over前面的字段放进over函数内
    2020-06-03 11:56
用户20462883Lv4见习互助
发布于2020-6-3 09:43
概念有点模糊,但我做过类似的,比如下方的SQL是实现分组后取每个分组的最大值,总共取前30条,也就是每个分组只取其中一条且是最大的那条数据:
select * from (
select a.variety ,
       to_char(to_date(a.in_store_date,'yyyy-mm-dd hh24:mi:ss'),'yyyy') 年份,
       max(ceil((to_date(nvl(a.out_store_date,to_char(sysdate,'yyyy-mm-dd hh24:mi:ss')), 'yyyy-mm-dd hh24:mi:ss') - To_date(a.in_store_date , 'yyyy-mm-dd hh24:mi:ss')))) 周转天数
from DWD_STOCK_01_N_2020 a
group by a.variety,to_char(to_date(a.in_store_date,'yyyy-mm-dd hh24:mi:ss'),'yyyy')
order by max(ceil((to_date(nvl(a.out_store_date,to_char(sysdate,'yyyy-mm-dd hh24:mi:ss')), 'yyyy-mm-dd hh24:mi:ss') - To_date(a.in_store_date , 'yyyy-mm-dd hh24:mi:ss')))) DESC
where rownum <= 30
黄金海岸Lv3见习互助
发布于2020-6-3 09:53
sum,order by,group by,limit
韩瀚荣Lv6初级互助
发布于2020-6-3 09:54
我正好前天刚看完这个方法,有4个排序函数,你看看那你需要哪个,肯定能解决你的问题,思路就是按照分组加一列序号,然后取前条就ok了,详细参考:
https://blog.csdn.net/qq_30725967/article/details/88572541
  • 718浏览人数
  • 最后回答于:2020-6-3 12:47
