根据不同选择执行不同的查询条件
根据不同选择执行不同的查询条件
例如选择一个字段为1,执行一个查询条件,选择一个字段为2,执行另一个查条件
history 发布于 2019-1-7 11:43
发布于2019-1-7 11:53(编辑于 2019-1-7 13:52)
select * from tabname where 1=1 ${if(参数名=1," and 字段1='内容1'"," and 字段2='内容2'")}
SQL结构大概这样,视情况自行扩展~
你的SQL语句中 where 都没有~不管sql如何千变万化~至少得保证语法正确呀~
SELECT
FROM
[ BMMES_JM ].[ dbo ].[ M_JOB_REPORTWORK ] where 1 = 1
${if(gdxh == "B"," and RpABMaterial = 'B' ",
if(gdxh=="A"," and CHARINDEX('_',RpERPWorkOrder)=0 and RpABMaterial = 'A' ",
if(gdxh=="返花", " and CHARINDEX('_',RpERPWorkOrder)>0 and RpABMaterial = 'A' " ,
 " and RpAuditStatus ='1'")))}
  • history history(提问者) 如果写成存储过程呢?
    2019-01-07 13:15
  • history history(提问者) 我原来是这样的 select * from [BMMES_JM].[dbo].[M_JOB_REPORTWORK] ${if(gdxh==\"B\",\" and RpABMaterial = \'B\' \",if(gdxh==\"A\",\" and CHARINDEX(\'_\',RpERPWorkOrder)=0 and RpABMaterial = \'A\' \",if(gdxh==\"返花\", \" and CHARINDEX(\'_\',RpERPWorkOrder)>0 and RpABMaterial = \'A\' \" , \" and RpAuditStatus =\'1\'\")))}
    2019-01-07 13:22
  • zsh331 zsh331 回复 history(提问者) 答案更新了,你再看看~亲,注意细节呀~
    2019-01-07 13:53
  • history history(提问者) 回复 zsh331 如果改成存储过程,怎么改
    2019-01-07 13:56
  • zsh331 zsh331 回复 history(提问者) sql用case when转换下就行...
    2019-01-07 14:04
  • 1354浏览人数
  • 最后回答于:2019-1-7 13:52
