环境如下: tomcat: 8.5 jdk: 1.8 现象: 独立部署没有问题,一切正常。 当和我的应用一起部署(嵌入式)部署时就报错,报错如下: log4j:ERROR A "com.fr.third.apache.log4j.ConsoleAppender" object is not assignable to a "org.apache.log4j.Appender" variable. log4j:ERROR The class "org.apache.log4j.Appender" was loaded by log4j:ERROR [ParallelWebappClassLoader context: web-admin delegate: false ----------> Parent Classloader: java.net.URLClassLoader@45a4b042 ] whereas object of type log4j:ERROR "com.fr.third.apache.log4j.ConsoleAppender" was loaded by [ParallelWebappClassLoader context: web-admin delegate: false ----------> Parent Classloader: java.net.URLClassLoader@45a4b042 ]. log4j:ERROR Could not instantiate appender named "console". 17:31:09 CommonExecutor-1-thread-1 ERROR [standard] invoked public abstract void com.fr.intelli.record.scene.Metric.pretreatment(java.util.List) throws java.lang.Exception=[Ljava.lang.Object;@5fb9c4bc 17:31:12 localhost-startStop-1 ERROR [standard] Lifecycle error.null java.lang.NullPointerException at com.fr.decision.webservice.WebServiceActivator.initUrlEncodeStyle(Unknown Source) at com.fr.decision.webservice.WebServiceActivator.start(Unknown Source) at com.fr.module.engine.FineModule.executeStart(Unknown Source) at com.fr.stable.lifecycle.AbstractLifecycle.start(Unknown Source) at com.fr.module.engine.FineModule.start(Unknown Source) at com.fr.module.engine.FineModule.startChildren(Unknown Source) at com.fr.module.engine.FineModule.executeStart(Unknown Source) at com.fr.stable.lifecycle.AbstractLifecycle.start(Unknown Source) at com.fr.module.engine.FineModule.start(Unknown Source) at com.fr.module.engine.FineModule.startChildren(Unknown Source) at com.fr.module.engine.FineModule.executeStart(Unknown Source) at com.fr.stable.lifecycle.AbstractLifecycle.start(Unknown Source) at com.fr.module.engine.FineModule.start(Unknown Source) at com.fr.module.engine.FineModule.startChildren(Unknown Source) at com.fr.module.engine.FineModule.executeStart(Unknown Source) at com.fr.stable.lifecycle.AbstractLifecycle.start(Unknown Source) at com.fr.module.engine.FineModule.start(Unknown Source) at com.fr.startup.FineWebApplicationStartup.executeStart(Unknown Source) at com.fr.stable.lifecycle.AbstractLifecycle.start(Unknown Source) at com.fr.startup.FineWebApplicationInitializer.onStartup(Unknown Source) at com.fr.third.springframework.web.SpringServletContainerInitializer.onStartup(SpringServletContainerInitializer.java:175) at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5204) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150) at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1419) at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1409) at java.util.concurrent.FutureTask.run(FutureTask.java:266) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at java.lang.Thread.run(Thread.java:745) 启动完成后,登录报错如下: 19:02:06 http-nio-8080-exec-6 ERROR [standard] java.lang.NullPointerException java.lang.NullPointerException at com.fr.decision.webservice.v10.login.lock.LoginLockService.unlockObject(Unknown Source) at com.fr.decision.webservice.v10.login.LoginService.doUserAuthentication(Unknown Source) at com.fr.decision.webservice.v10.login.LoginService.login$original$JeV2J0yD(Unknown Source) at com.fr.decision.webservice.v10.login.LoginService.login$original$JeV2J0yD$accessor$YTxltRDY(Unknown Source) at com.fr.decision.webservice.v10.login.LoginService$auxiliary$UV8KkSy5.call(Unknown Source) at com.fr.record.analyzer.TimeInterceptor.intercept(Unknown Source) at com.fr.decision.webservice.v10.login.LoginService.login(Unknown Source) at com.fr.web.controller.decision.api.auth.LoginResource.login(Unknown Source) at com.fr.web.controller.decision.api.auth.LoginResource$$FastClassBySpringCGLIB$$3cc36614.invoke() at com.fr.third.springframework.cglib.proxy.MethodProxy.invoke(MethodProxy.java:201) at com.fr.third.springframework.aop.framework.CglibAopProxy$CglibMethodInvocation.invokeJoinpoint(CglibAopProxy.java:710) at com.fr.third.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:157) at com.fr.third.springframework.aop.framework.adapter.MethodBeforeAdviceInterceptor.invoke(MethodBeforeAdviceInterceptor.java:52) at com.fr.third.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:168) at com.fr.third.springframework.aop.framework.adapter.AfterReturningAdviceInterceptor.invoke(AfterReturningAdviceInterceptor.java:52) at com.fr.third.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:168) at com.fr.third.springframework.aop.interceptor.ExposeInvocationInterceptor.invoke(ExposeInvocationInterceptor.java:92) at com.fr.third.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179) at com.fr.third.springframework.aop.framework.CglibAopProxy$DynamicAdvisedInterceptor.intercept(CglibAopProxy.java:646) at com.fr.web.controller.decision.api.auth.LoginResource$$EnhancerBySpringCGLIB$$314dc8fe.login() at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:497) at com.fr.third.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:221) at com.fr.third.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:137) at com.fr.third.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:104) at com.fr.third.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandleMethod(RequestMappingHandlerAdapter.java:747) at com.fr.third.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:676) at com.fr.third.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:85) at com.fr.third.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:938) at com.fr.third.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:870) at com.fr.third.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:961) at com.fr.third.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:863) at javax.servlet.http.HttpServlet.service(HttpServlet.java:661) at com.fr.third.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:837) at javax.servlet.http.HttpServlet.service(HttpServlet.java:742) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at com.alibaba.druid.support.http.WebStatFilter.doFilter(WebStatFilter.java:123) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at org.apache.shiro.web.servlet.ProxiedFilterChain.doFilter(ProxiedFilterChain.java:61) at org.apache.shiro.web.servlet.AdviceFilter.executeChain(AdviceFilter.java:108) at org.apache.shiro.web.servlet.AdviceFilter.doFilterInternal(AdviceFilter.java:137) at org.apache.shiro.web.servlet.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:125) at org.apache.shiro.web.servlet.ProxiedFilterChain.doFilter(ProxiedFilterChain.java:66) at org.apache.shiro.web.servlet.AdviceFilter.executeChain(AdviceFilter.java:108) at org.apache.shiro.web.servlet.AdviceFilter.doFilterInternal(AdviceFilter.java:137) at org.apache.shiro.web.servlet.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:125) at org.apache.shiro.web.servlet.ProxiedFilterChain.doFilter(ProxiedFilterChain.java:66) at org.apache.shiro.web.servlet.AdviceFilter.executeChain(AdviceFilter.java:108) at org.apache.shiro.web.servlet.AdviceFilter.doFilterInternal(AdviceFilter.java:137) at org.apache.shiro.web.servlet.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:125) at org.apache.shiro.web.servlet.ProxiedFilterChain.doFilter(ProxiedFilterChain.java:66) at org.apache.shiro.web.servlet.AbstractShiroFilter.executeChain(AbstractShiroFilter.java:449) at org.apache.shiro.web.servlet.AbstractShiroFilter$1.call(AbstractShiroFilter.java:365) at org.apache.shiro.subject.support.SubjectCallable.doCall(SubjectCallable.java:90) at org.apache.shiro.subject.support.SubjectCallable.call(SubjectCallable.java:83) at org.apache.shiro.subject.support.DelegatingSubject.execute(DelegatingSubject.java:387) at org.apache.shiro.web.servlet.AbstractShiroFilter.doFilterInternal(AbstractShiroFilter.java:362) at org.apache.shiro.web.servlet.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:125) at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:347) at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:263) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:197) at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at com.fr.decision.base.DecisionServletInitializer$4.doFilter(Unknown Source) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:199) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81) at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:650) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:342) at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:803) at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66) at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:790) at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1459) at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) at java.lang.Thread.run(Thread.java:745) 嵌入式部署的过程是严格按照帮助文档进行的,反复尝试多次都不行。 |
