选中复选框点击回复,跳出另一个模板,但是没有数据是咋回事? var $span = $('.fr-checkbox-checkon'); //获取选中的复选框 var $tds = $("td").has($span); //定义选中复选框的单元格 var $trs = $("tr").has($tds); for (var i = 0; i < $trs.length; i++) { var name = $("td:eq(1)", $($trs[i])).find("div").html(); var name2 = $("td:eq(8)", $($trs[i])).find("div").html(); var a = $("td:eq(3)", $($trs[i])).html(); var b = $("td:eq(4)", $($trs[i])).html(); var $iframe = $("<iframe id='inp' name='inp' width='100%' height='100%' scrolling='no' frameborder='0'>"); $iframe.attr("src", "${servletURL}?reportlet=重点任务维护(部门间)1/重点协调事项维护-回复.cpt&op=write"+"&num="+name+"task1="+name2); var o = { title : "", width : 1799, height: 850 }; FR.showDialog(o.title, o.width, o.height, $iframe,o); }
