JS实现点击控件跳转到其他报表,跳转已完成,但是怎么把父报表的参数传递到子报表?求帮忙看看JS代码
//根据控件名称获取控件值
var aa = this.options.form.getWidgetByName("STARTDATE").getValue();
var bb = this.options.form.getWidgetByName("ENDDATE").getValue();
var cc = this.options.form.getWidgetByName("CONTROL_TYPE").getValue();
var reportUrl =FR.cjkEncode("${servletURL}?viewlet=MFG/PMS_ACHIEVE_RATE_review_drilldown.cpt&op=view&startdate=")+aa+"&enddate="+bb+"&control_type="+cc
//打开
var $iframe = $("
$iframe.attr("src", "${servletURL}?reportlet=MFG/PMS_ACHIEVE_RATE_review_drilldown.cpt&op=view");
var o = {
title : "PMS_ACHIEVE&SUCCESS_RATE",
width : 1100,
height: 500
FR.showDialog(o.title, o.width, o.height, $iframe,o);
$('.fr-core-window').css("background","rgb(248,240,203)");
$('.fr-core-window .fr-core-window-header ').css("background","rgb(35,152,216)");
$('.ui-resizable-e').css("background","rgb(71,168,234)");
小八路小八路 发布于 2020-9-8 16:50 (编辑于 2020-9-8 17:09)
axingLv6专家互助
发布于2020-9-8 17:02
/根据控件名称获取控件值
var reportUrl =FR.cjkEncode("${servletURL}?viewlet=MFG/PMS_ACHIEVE_RATE_review_drilldown.cpt&op=view&startdate="+aa+"&enddate="+bb+"&control_type="+cc)
//打开
var $iframe = $("<iframe id='inp' name='inp' width='100%' height='100%' scrolling='no' frameborder='0'>");
$iframe.attr("src", reportUrl);
var o = {
width : 1100,
height: 500
括号没写对,reportUrl定义好之后,下面直接引用就行
luojian0323Lv7资深互助
发布于2020-9-8 16:56
多个括号
ColdmanLv6高级互助
发布于2020-9-8 17:10(编辑于 2020-9-8 17:17)
/根据控件名称获取控件值
//打开
var o = {
width : 1100,
height: 500
  • 小八路小八路 小八路小八路(提问者) JS代码里面已经添加好参数了 var aa = this.options.form.getWidgetByName(\"STARTDATE\").getValue(); var bb = this.options.form.getWidgetByName(\"ENDDATE\").getValue(); var cc = this.options.form.getWidgetByName(\"CONTROL_TYPE\").getValue(); var reportUrl =FR.cjkEncode(\"${servletURL}?viewlet=MFG/PMS_ACHIEVE_RATE_review_drilldown.cpt&op=view&startdate=\")+aa+\"&enddate=\"+bb+\"&control_type=\"+cc
    2020-09-08 17:12
  • Coldman Coldman 回复 小八路小八路(提问者) 看新回复试试
    2020-09-08 17:17
  • 小八路小八路 小八路小八路(提问者) 回复 Coldman 没有用,报错SyntaxError: Invalid or unexpected token
    2020-09-09 08:45
  • 1184浏览人数
  • 最后回答于:2020-9-8 17:17
